Hello I am using Inventor Pro HSM 2018 and I'm trying to log into Vault Professional 2018 server on a standalone local host and I get a error "The license obtained is incompatible with the server" I was able to log in to the vault server with inventor pro hsm 2017 & vault basic 2017 but now after I upgraded I'm not able to.
Thank you
Solved by bharath.kumar99. Go to Solution.
Are you still experiencing this issue? If you are, I suggest that you uninstall Vault Professional 2018 Client (and any other Vault Clients you may have) and re-install Vault Professional 2018 Client. And try again.
Hope that helps.
Regards
Hi There,
We've documented the solution for this problem in the below article and it has helped most of our users, please do give it a try -
