Include a Forward Slash (/) in File Name
amitnkukanur
amitnkukanur
I am doing customization for Vault professional 2013 and using C#.net (VS 2010) as Development Language.As per customer requirement they need a file naming system in Vault is respective folders.
As per customer requirement they need to include a forward slash i.e.  / in the file names.
I tried to rename it manually, my problem is it possible to rename using coding to include such special characters in file names.
rgds
Amit
Senior Software Engineer
minkd
No it is not possible to include invalid characters in a file name.  If it were allowed, you would not be able to store the file on a windows filesystem.
-Dave
Dave Mink
Fusion Lifecycle
Autodesk, Inc.
amitnkukanur
Ok, Mink. Thanks for the information provided
Regards
Amit
FaridNacer
Instead of using a slash ("/"), you could use a fraction slash ("⁄") or a division slash ("⁄") which are usually indistinguishable (to the human eye, at least), especially when not next to a common slash. Here's an example in WIndows:
and the same file in Vault:
I created the above slash by holding the Alt key and entering 8260 on the numeric keypad.
It's an odd solution. But then again, the client request seems equally odd.
amitnkukanur
Hello FaridNacer,
The idea which you specified is not working here
rgds
amit
8500jagadeesh1
Community Visitor
Community Visitor
There is something called fraction symbol, Please see this link https://www.alt-codes.net/fraction-symbols
You can copy required fraction symbol and paste it in your file, it works well.
Have it a go!
