Getting current logged in user
jaapflonk
jaapflonk
I made a few custom tools in Vault that i want to hide for people who are not admin or lead engineer.
The problem is that VDF.Vault.Library.ConnectionManager.LogIn() requires a password and a name. Right now i hardcoded the admin credentials to call this function and it will return a Connection object with the admin credentials inside (ofcourse).
What i want is to call VDF.Vault.Library.ConnectionManager.LogIn() with the credentials of the user that is logged in:
Or another solution would be to still login as admin in my code,  but somehow get the current logged in user in Vault:
Some help or example code would be greatly appreciated!
Markus.Koechl
A standalone application requires a dedicated login, like Inventor and Vault Explorer login explicitly. So, Vault extensions can re-use the VE connection, or other Inventor Add-Ins can re-use the Inventor-Vault connection.
Markus Koechl
Solutions Engineer PDM, Autodesk Central Europe
jaapflonk
Thanks for the reply @Markus.Koechl
I got it to work.
