Get 'List of Values' for Vault Property
ThomasRambach
Advisor Advisor
ThomasRambach
In Vault, you have the ability to provide a list of values for a property. Users then can pick from the list of values as the value of the property.
I can't find in the API a method to retrieve that list of values for a property. Is this possible?
woodstylee3
OK hopefully this makes some sense:
So each PropDefInfo contains an Array of Constraints.
One of Which may be a EnforceListOfValues Constraint
Each EnforceListOfValues Constraint has a property ListValArray
which is the list vals
so with prpdefifos =  PropDefInfo[]
var propconstraints = prpdefifos.SelectMany(x=> x.PropConstrArray);
if (propconstraints.Where(cst => cst.PropConstrTyp == Autodesk.Connectivity.WebServices.PropConstrTyp.EnforceListOfValues).Count() >0)
ArrayofVals =  prpdefifos.Where(x => x.ListValArray != null).First().ListValArray.Select(x => x.ToString()).ToArray()));
ThomasRambach
Thanks @woodstylee3
From your code, this was my result for just getting the list of acceptable values for a property called "Drawing Type":
                PropertyService PropSrvc = context.Connection.WebServiceManager.PropertyService;
                ACW.PropDef[] filePropDefs = mWsMgr.PropertyService.GetPropertyDefinitionsByEntityClassId("FILE");
                PropDef drawingtypePropDef = filePropDefs.Single(n => n.DispName == "Drawing Type");
                ACW.PropDefInfo[] filePropDefInfo = mWsMgr.PropertyService.GetPropertyDefinitionInfosByEntityClassId("FILE", new long[]{ drawingtypePropDef.Id });
                var arrayDrawingType = filePropDefInfo.Where(x => x.ListValArray != null).First().ListValArray.Select(x => x.ToString()).ToArray();
