file.xaml
<?xml version="1.0" encoding="utf-8"?>
<WPF:MainWindow xmlns="http://schemas.microsoft.com/winfx/2006/xaml/presentation"
xmlns:x="http://schemas.microsoft.com/winfx/2006/xaml"
xmlns:scm="clr-namespace:System.ComponentModel;assembly=WindowsBase"
x:Name="FileWindow"
xmlns:WPF="clr-namespace:CreateObject.WPF;assembly=CreateObject"
AllowsTransparency="False" Background="#F0F0F0" ResizeMode="NoResize" SizeToContent="WidthAndHeight">
<Window.Resources>
<Style x:Key="DynamicDataGridCellStyle" TargetType="{x:Type DataGridCell}">
<Setter Property="KeyboardNavigation.IsTabStop" Value="False" />
<Setter Property="Template">
<Setter.Value>
<ControlTemplate>
<ComboBox ItemsSource="{Binding ListValues}"
Text="{WPF:ValidatedBinding Value, StringFormat=N}" IsEditable="True"
BorderThickness="0" />
</ControlTemplate>
</Setter.Value>
</Setter>
<Style.Triggers>
<Trigger Property="IsSelected" Value="True">
<Setter Property="Background" Value="{DynamicResource {x:Static SystemColors.HighlightBrushKey}}" />
<Setter Property="Foreground"
Value="{DynamicResource {x:Static SystemColors.HighlightTextBrushKey}}" />
<Setter Property="BorderBrush" Value="{DynamicResource {x:Static SystemColors.HighlightBrushKey}}" />
</Trigger>
<Trigger Property="IsKeyboardFocusWithin" Value="True">
<Setter Property="BorderBrush" Value="{DynamicResource {x:Static DataGrid.FocusBorderBrushKey}}" />
</Trigger>
<DataTrigger Binding="{Binding EnforceListValues}" Value="True">
<Setter.Value>
<ControlTemplate>
<ComboBox ItemsSource="{Binding ListValues}" SelectedItem="{WPF:ValidatedBinding Value}"
BorderThickness="0"/>
</ControlTemplate>
</Setter.Value>
</Setter>
</DataTrigger>
<DataTrigger Binding="{Binding ListValues.Count}" Value="0">
<Setter.Value>
<ControlTemplate>
<TextBox Text="{WPF:ValidatedBinding Value, StringFormat=N}" BorderThickness="0" CharacterCasing="{Binding Case}" />
</ControlTemplate>
</Setter.Value>
</Setter>
</DataTrigger>
<DataTrigger Binding="{Binding Typ}" Value="DateTime">
<Setter.Value>
<ControlTemplate>
<DatePicker SelectedDate="{WPF:ValidatedBinding Value}" SelectedDateFormat="Short"/>
</ControlTemplate>
</Setter.Value>
</Setter>
</DataTrigger>
<DataTrigger Binding="{Binding Typ}" Value="Bool">
<Setter.Value>
<ControlTemplate>
<ComboBox Text="{WPF:ValidatedBinding Value}" IsEditable="True">
<ComboBoxItem Content="True" />
<ComboBoxItem Content="False" />
</ComboBox>
</ControlTemplate>
</Setter.Value>
</Setter>
</DataTrigger>
</Style.Triggers>
</Style>
<Style x:Key="DynamicDataGridLabelStyle" TargetType="{x:Type DataGridCell}">
<Setter Property="Height" Value="22" />
<Setter Property="Margin" Value="0,4,0,0" />
<Setter Property="BorderThickness" Value="0" />
<Setter Property="I****TestVisible" Value="False" />
</Style>
<Style TargetType="{x:Type Label}" BasedOn="{StaticResource {x:Type Label}}">
<Setter Property="Margin" Value="0,0,0,0" />
<Setter Property="Padding" Value="5,3,3,2" />
<Setter Property="VerticalAlignment" Value="Stretch" />
<Setter Property="HorizontalAlignment" Value="Stretch" />
<Setter Property="BorderBrush" Value="#FFABADB3" />
<Setter Property="BorderThickness" Value="1,1,1,0" />
<Style.Triggers>
<DataTrigger Binding="{Binding Content, RelativeSource={RelativeSource Self}}" Value="{x:Null}">
<Setter Property="BorderThickness" Value="1" />
<Setter Property="BorderBrush" Value="#ff0000" />
</DataTrigger>
</Style.Triggers>
</Style>
<Style TargetType="{x:Type TextBox}" BasedOn="{StaticResource {x:Type TextBox}}">
<Setter Property="VerticalContentAlignment" Value="Center" />
<Setter Property="BorderThickness" Value="0,1,1,0" />
<Setter Property="TextWrapping" Value="Wrap"></Setter>
<Style.Triggers>
<Trigger Property="Validation.HasError" Value="true">
<Setter Property="ToolTip"
Value="{Binding (Validation.Errors)[0].ErrorContent, RelativeSource={x:Static RelativeSource.Self}}" />
</Trigger>
<DataTrigger Binding="{Binding IsReadOnly, RelativeSource={RelativeSource Self}}" Value="True">
<Setter Property="Background" Value="{DynamicResource {x:Static SystemColors.WindowColorKey}}" />
</DataTrigger>
</Style.Triggers>
</Style>
<Style TargetType="{x:Type ComboBox}" BasedOn="{StaticResource {x:Type ComboBox}}">
<Setter Property="Background" Value="{DynamicResource {x:Static SystemColors.ControlLightLightBrushKey}}" />
<Style.Triggers>
</Trigger>
</Style.Triggers>
</Style>
<Style TargetType="{x:Type DatePicker}">
<Style.Triggers>
</Trigger>
</Style.Triggers>
</Style>
<Style x:Key="Required" TargetType="{x:Type TextBox}" BasedOn="{StaticResource {x:Type TextBox}}">
<Style.Triggers>
<DataTrigger Binding="{Binding Text, RelativeSource={RelativeSource Self}}" Value="">
<Setter Property="BorderBrush" Value="Red" />
<Setter Property="BorderThickness" Value="1,1,1,1" />
</DataTrigger>
</Style.Triggers>
</Style>
<Style x:Key="NumSchmCtrlStyle" TargetType="{x:Type WPF:DSNumSchemeCtrl}">
<Setter Property="Height" Value="Auto" />
<Setter Property="ToolTipService.ShowOnDisabled" Value="True" />
<Setter Property="BorderBrush" Value="Gray" />
<Style.Triggers>
<DataTrigger Binding="{Binding EditMode}" Value="True">
<Setter Property="Visibility" Value="Collapsed" />
</DataTrigger>
</Style.Triggers>
</Style>
<Style x:Key="TemplateCbStyle" TargetType="{x:Type ComboBox}" BasedOn="{StaticResource {x:Type ComboBox}}">
<Style.Triggers>
<DataTrigger Binding="{Binding CreateMode}" Value="True">
<Setter Property="ItemsSource" Value="{Binding Templates}" />
</DataTrigger>
</DataTrigger>
<DataTrigger Binding="{Binding ElementName=TemplateTB, Path=Visibility}" Value="Visible">
</DataTrigger>
</Style.Triggers>
</Style>
<Style x:Key="ButtonGridStyle" TargetType="{x:Type Grid}">
<Setter Property="Margin" Value="0,15,2,5" />
</Style>
<BooleanToVisibilityConverter x:Key="BooleanToVisibilityConverter" />
<CollectionViewSource x:Key="TemplatesViewSource" Source="{Binding Path=Templates}">
<CollectionViewSource.SortDescriptions>
<scm:SortDescription PropertyName="Name" />
</CollectionViewSource.SortDescriptions> </CollectionViewSource>
</Window.Resources>
<Grid x:Name="grdMain" Margin="5,0,0,0">
<Grid.RowDefinitions>
<RowDefinition Height="Auto" ToolTip="Template Folder"/>
<RowDefinition Height="Auto" />
</Grid.RowDefinitions>
<Grid.ColumnDefinitions>
<ColumnDefinition Width="Auto" />
<ColumnDefinition />
</Grid.ColumnDefinitions>
<GroupBox x:Name="GroupFolder" Grid.ColumnSpan="2" Margin="-6,0,0,5" BorderThickness="0" Header="{Binding UIString[LBL1], FallbackValue=Folder}" Visibility="{Binding CreateMode, Converter={StaticResource BooleanToVisibilityConverter}}">
<WrapPanel x:Name="BreadCrumb"
ItemWidth="165" Margin="1,0,0,0">
<WrapPanel.Resources>
<Style TargetType="{x:Type ComboBox}">
<Setter Property="Margin" Value="-1,0,0,0" />
<Setter Property="ToolTip" Value="{Binding SelectedValue.Name, RelativeSource = {RelativeSource Self}}"/>
</Style>
</WrapPanel.Resources>
</WrapPanel>
</GroupBox>
<Grid x:Name="grdGeneralProps" Margin="0,45,0,0"
ToolTip="{Binding UIString[LBL73], FallbackValue='General Properties'}"
Width="Auto">
<RowDefinition Height="auto" />
<ColumnDefinition Width="140"/>
<ColumnDefinition Width="220"/>
<Label Content="{Binding UIString[LBL8], FallbackValue=Categories}" Grid.Row="0" Grid.Column="0" />
<ComboBox x:Name="Categories" ItemsSource="{Binding PsList[GetCategories], Mode=OneTime}"
DisplayMemberPath="Name" SelectedItem="{Binding DynamicPropertiesCategory}"
SelectedValuePath="Name" SelectedValue="{Binding Prop[_Category].Value}" SelectedIndex="0"
Grid.Row="0" Grid.Column="1"
IsEnabled="{Binding CreateMode}" />
<Label Content="{Binding UIString[LBL9], FallbackValue=Templates}" Grid.Row="4" Grid.Column="0" >
<Label.Style>
<Style TargetType="{x:Type Label}">
<Style.Triggers>
<MultiDataTrigger>
<MultiDataTrigger.Conditions>
<Condition Binding="{Binding EditMode}" Value="True" />
<Condition Binding="{Binding Visibility, ElementName=TemplateCB}"
</MultiDataTrigger.Conditions>
</MultiDataTrigger>
</Style.Triggers>
</Style>
</Label.Style>
</Label>
<ComboBox x:Name="TemplateCB" ItemsSource="{Binding Source={StaticResource TemplatesViewSource}}" Grid.Row="4" Grid.Column="1" IsSynchronizedWithCurrentItem="True" SelectedItem="{Binding SelectedTemplate}" Style="{StaticResource TemplateCbStyle}" />
<TextBox x:Name="TemplateTB" Grid.Row="4" Grid.Column="1" Text="{Binding UIString[LBL28]}" I****TestVisible="False">
<TextBox.Style>
<Style TargetType="{x:Type TextBox}">
<Style.Triggers>
<MultiDataTrigger>
<Condition Binding="{Binding SelectedItem, ElementName=TemplateCB}"
Value="{x:Null}" />
<Condition Binding="{Binding CreateMode}" Value="True" />
<Setter Property="Visibility" Value="Visible" />
<Setter Property="Background" Value="#F0F0F0" />
</MultiDataTrigger>
</Style.Triggers>
</Style>
</TextBox.Style>
</TextBox>
<Label Content="{Binding UIString[LBL10],FallbackValue=Numberingscheme}" Grid.Column="0" Grid.Row="5"
Visibility="{Binding Visibility, ElementName=NumSchms}" />
<ComboBox Grid.Column="1" Grid.Row="5"
x:Name="NumSchms" DisplayMemberPath="Name"
SelectedValue="{Binding Prop[_NumSchm].Value}"
ItemsSource="{Binding PsList[GetNumSchms], Mode=OneTime}"
IsEnabled="{Binding HasItems, RelativeSource={RelativeSource Self}}"
Visibility="{Binding NotEditMode, Converter={StaticResource BooleanToVisibilityConverter}}" />
<Label Content="{Binding UIString[LBL31], FallbackValue=Number}" Grid.Column="0" Grid.Row="6" Height="Auto"
Visibility="{Binding Visibility, ElementName=DSNumSchmsCtrl}" />
<WPF:DSNumSchemeCtrl Grid.Column="1" Grid.Row="6" x:Name="DSNumSchmsCtrl"
IsEnabled="{Binding ElementName=NumSchms, Path=IsEnabled}"
Scheme="{Binding ElementName=NumSchms, Path=SelectedItem}"
GeneratedNumberProperty="_GeneratedNumber" Style="{StaticResource NumSchmCtrlStyle}" />
<Label Content="{Binding UIString[LBL5],FallbackValue=Path}" Grid.Column="0" Grid.Row="8"
BorderThickness="1" />
<TextBox Text="{WPF:ValidatedBinding Prop[_FilePath].Value}" Grid.Column="1" Grid.Row="8" IsReadOnly="True"
IsTabStop="False" BorderThickness="0,1,1,1" />
<Label Content="{Binding UIString[LBL6],FallbackValue=Filename}" Grid.Row="7" Grid.Column="0"
Visibility="{Binding NumSchmFieldsEmpty, ElementName=DSNumSchmsCtrl, Converter={StaticResource BooleanToVisibilityConverter}}" />
<TextBox Grid.Row="7" Grid.Column="1" x:Name="FILENAME" Text="{WPF:ValidatedBinding Name}"
IsTabStop="False"
</Grid>
<DataGrid Grid.Column="1" x:Name="DSDynCatPropGrid" MaxHeight="350"
ItemsSource="{Binding DynamicProperties}"
ToolTip="{Binding UIString[LBL63], FallbackValue='Category Properties'}"
AutoGenerateColumns="False"
HeadersVisibility="Column"
ScrollViewer.CanContentScroll="True"
HorizontalGridLinesBrush="WhiteSmoke"
VerticalGridLinesBrush="WhiteSmoke" BorderBrush="Gray" MaxWidth="600"
Margin="30,45,25,0" VerticalAlignment="Top">
<DataGrid.Columns>
<DataGridTextColumn Binding="{Binding Name}" CellStyle="{StaticResource DynamicDataGridLabelStyle}"
MinWidth="160" Width="Auto" IsReadOnly="True">
<DataGridTextColumn.HeaderTemplate>
<DataTemplate>
<TextBlock
Text="{Binding DataContext.UIString[LBL64], RelativeSource={RelativeSource AncestorType={x:Type DataGrid}}}" />
</DataTemplate>
</DataGridTextColumn.HeaderTemplate>
</DataGridTextColumn>
<DataGridTextColumn Binding="{Binding Value}" Width="*"
CellStyle="{StaticResource DynamicDataGridCellStyle}" IsReadOnly="True">
<DataTemplate>
<TextBlock
Text="{Binding DataContext.UIString[LBL65], RelativeSource={RelativeSource AncestorType={x:Type DataGrid}}}" />
</DataTemplate>
</DataGrid.Columns>
</DataGrid>
<Grid x:Name="ButtonGrid" Style="{StaticResource ButtonGridStyle}" Grid.Row="3" Grid.ColumnSpan="2">
<ColumnDefinition Width="80" />
<ColumnDefinition Width="20" />
<GroupBox x:Name="TemplatePath" Header="{Binding UIString[TLT2], FallbackValue=Template Path}" Grid.Row="1" Grid.ColumnSpan="3" BorderThickness="0" Margin="-6,0,0,0"
ToolTip="{Binding UIString[TLT2], FallbackValue='Template Path'}">
<TextBox x:Name="TemplatePathTB" Text="{Binding TemplatePath}"
IsReadOnly="True"
Background="#F0F0F0" BorderThickness="1" Margin="0,0,-6,0" />
</GroupBox>
<Button x:Name="btnOK" Content="{Binding UIString[BTN1], FallbackValue=OK}"
Command="{Binding CloseWindowCommand, ElementName=FileWindow}" IsEnabled="{Binding IsNotReadonly}" Grid.Row="2"
Grid.Column="2" Width="80" Height="24" IsDefault="True" />
<Button x:Name="btnEsc" Content="{Binding UIString[BTN2], FallbackValue=Esc}"
Command="{Binding CancelWindowCommand, ElementName=FileWindow}" Grid.Row="2" Grid.Column="4" Width="80"
HorizontalAlignment="Right" Height="24" IsCancel="True" />
</Grid>
</Grid>
</WPF:MainWindow>
