Data standard Date type problem
I have a problem with a "Date" type of a property. I have modified the DataStandard with some textboxes, this textboxes are binding to some properties, one of this properties is a "Date" type property. The problem is When I press the "OK" button and the file is created the property(with date type) is empty
//WPF
Text="{Binding Prop[*Fecha_revision].Value}"
//Powershell
$Prop["*Fecha_revision"].Value = Get-Date -Format d;
How Can I bind the texbox and the property(DATE type) correctly?
Thank you so much!
manuel.lanthaler
how did you define the Property in the Inventor.cfg ?
Get sure you are using the correct type:
<PropertyDefinition PropertyName="*Fecha_revision" DataType="Date"
Manuel
coolOrange
www.coolOrange.com
If you have found any post to be helpful, even if it's not a direct solution, then please provide that author kudos.
No, in this case the data standard is for the Vault not Inventor.
manuel.lanthaler
the problem is in your powerShell script.
The "Get-Date -f d" is returning the date as type string but the vault wants a DateTime object.
So you have to get sure that you are setting the property with a "DateTime" object.
Example:
 Get-Date
[System.DateTime]::Today
[datetime]:: Parse("30/01/15")
Manuel
coolOrange
www.coolOrange.com
With "Get-Date" (Without format) it works.
Thank you so much!
