BOMComp[] access
BOMComp[] access
Jakub.Szymanik
BOMComp[] access
Jakub.Szymanik
One question regarding BOMComp[], what is the correct way to get to this? Please look at this function:
private void HandleBOMSelection(ISelection oneSelection, Connection oneConnection)
    Item selectedItem = oneConnection.WebServiceManager.ItemService.GetItemsByIds(new long[] { oneSelection.Id }).FirstOrDefault();
    ItemBOM itemBom = oneConnection.WebServiceManager.ItemService.GetItemBOMByItemIdAndDate(selectedItem.Id, selectedItem.LastModDate, BOMTyp.Historic,
                        BOMViewEditOptions.Defaults | BOMViewEditOptions.ReturnOccurrences | BOMViewEditOptions.ReturnUnassignedComponents);
    var itemBomAssocArray = itemBom.ItemAssocArray;
    var itemBomRevArray = itemBom.ItemRevArray;
    var itemBomCompArray = itemBom.BOMCompArray;
    string string_itemBomAssocArray = string.Join("\n", itemBomAssocArray.Select(item => string.Join(", ", item.GetType().GetProperties().Select(prop => $"{prop.Name}: {prop.GetValue(item)}"))));
    string string_itemBomRevArray = string.Join("\n", itemBomRevArray.Select(item => string.Join(", ", item.GetType().GetProperties().Select(prop => $"{prop.Name}: {prop.GetValue(item)}"))));
    string string_itemBomRevArray = string.Join("\n", itemBomCompArray.Select(item => string.Join(", ", item.GetType().GetProperties().Select(prop => $"{prop.Name}: {prop.GetValue(item)}"))));
itemBomAssocArray and itemBomRevArray are ok, however itemBomCompArray is null. Why?
jofa73W96
Not sure if it is helpful but here is a link I found useful on this topic: Component BOM Rows - It's All Just Ones and Zeros
Jakub.Szymanik
Thanks for the reply, but I already saw this post and still I don't know what I need to fix in my code to get rid of the null.
