AddFile with children
m_baczewski
m_baczewski
Is there an alternative method for inputting and adding files to Vault in this context
ThisApplication.CommandManager.ControlDefinitions.Item("VaultCheckinTop")
 I tried adding a file using AddFile, but the issue is that all the files lose their associations with each other.
I would like to accomplish this because I have written an application (a configurator) that handles the entire workflow, and I want to avoid using Inventor's UI commands.
Is there a solution to this problem? Or is adding files to Vault using Inventor's UI the safest and best approach?
Markus.Koechl
Adding files to Vault using
 is the only supported approach. Besides file references, the BOM or multiple BOMs (Model States) are the reason for it.
Markus Koechl
Solutions Engineer PDM, Autodesk Central Europe
m_baczewski
@Markus.Koechl
Thanks for the information. That's what I suspected.
