Working with Vault and ANSYS?
Hello guys,
I am working with Vault and now I want to add my  Ansys-data. Does anyone has a tip for that? And how do you work with Vault, when u have other data except of CAD?
Thank you
darius.simkunas
It is no problems when you have any type of 1 file.
You check out, open with your app and after check in.
There is a problem when you need to work with one file which use other files and create new ones on working process.
Something like work with GIS project which contains separate shp files.
In this cases we let use Network drive and upload some result which is necessary for the team, for example exported to CAD file. This file will needs to be updated manually.
Darius
