VP2024 Connecting to API is not letting us thru (error 404)
steveh3
Advisor Advisor
steveh3
Gang...
In VP2024 we have separated our ADMS and SQL into two separate servers. All is well from that end and we can log into Thick Client with no issues.
We are now attempting to pierce into the servers using API and having trouble logging in.
We are getting an error 404.
We had had no issues in the past with VP2023 when we had SQL and ADMS on same server.
Attached an image of our error on the calls we are using....
dbServername is our SQL servername
fileServerName is our ADMS servername
also username and passwaod does work when logging in via Thick Client.
Thoughts?
Thank you in advance,
Steve Hilvers
Steve Hilvers
Inventor Certified User / Vault Professional Influencer
steveh3
I moved this from Vault discussion group...
https://forums.autodesk.com/t5/vault-forum/vp2024-connecting-to-api-is-not-letting-us-thru-error-404...
Steve Hilvers
steveh3
We ended up grabbing the latest .dll's from the 2024 SDK's and it is now working.
Thanks all.
Steve Hilvers
