VDS - Numbering Schemes
AIT-Hermann
AIT-Hermann
I wanted to display all active number schemes, displaying the default first. That works. But I don't get the 'None' displayed.
My code:
$_FilteredNumSchems = @()
$_Default = $numSchems | Where-Object { $_.IsDflt -eq $true }
$_FilteredNumSchems += ($_Default) | Sort-Object
if ($Prop["_NumSchm"].Value) { $Prop["_NumSchm"].Value = $_FilteredNumSchems[0].Name } #note - functional dialogs don't have the property _NumSchm, therefore we conditionally set the value
$dsWindow.FindName("NumSchms").IsEnabled = $true
$dsWindow.FindName("NumSchms").SelectedValue = $_Default.Name
#add the "None" scheme to allow user interactive file name input
$noneNumSchm = New-Object 'Autodesk.Connectivity.WebServices.NumSchm'
$noneNumSchm.Name = $UIString["LBL77"] # None
$Prop["_NumSchm"].Value = $_default.Name
return $numSchems
I found a few posts but can't find the solution.
Can someone help me without completely rebuilding the CodeBlock?
Markus.Koechl
Hi @AIT-Hermann : you must add the $noneNumSchm to the list of numbering schemes before return it; compare the full code sample here: VDS-Sample-Configurations-2026/VDS-MFG-Sample/CAD.Custom/addins/ADSK.QS.Default.ps1 at master · koec...
I hope this helps.
Markus Koechl
Solutions Engineer PDM, Autodesk Central Europe
AIT-Hermann
Hi Markus,
i had used like this.
But when I use the code in this way, only the default numbering scheme is displayed and 'None'.
All others activated in Vault are missing.
Markus.Koechl
Hi Michael, @AIT-Hermann : that's the intent of the list $_FilteredNumSchems. You could skip filtering and add the "None" scheme to the full list like this:
$numSchems += $noneNumSchm
return $numSchems
Don't forget to return the unfiltered list of schemes instead of the filtered ones. My code returns the filtered only.
Markus Koechl
AIT-Hermann
That is exactly the solution.
Thank you very much.
