VDS in Inventor crashing with Customised XAML
Nick_Hall
Nick_Hall
Hi
I am trying to create a customised UI for the "Display Datasheet" & "Copy current document" commands. The Inventor.xaml file and the .ps1 files are quite heavily customised.
I've run into an issue where the following message box appears most of the time I run the "Copy current document" command.
Sometimes, it is followed by this message box.
Whether the second message occurs or not, the result is almost always that Inventor becomes unresponsive apart from the Minimise, Maximise and Close buttons, although sometimes it will kill Inventor completely, and I can submit a crash report.
The form opens reliably when using the "Display Datasheet" command, which points me to something happening when it is opened with $Prop["_CreateMode"] set.
Has anyone got any ideas about how to debug this issue?
Any help gratefully received
Nick
Nick_Hall
With some help from an eagle-eyed colleague, I tracked it down to some iLogic running on the After Open Document trigger.
Panic Over!!
