VDFv.Forms.Currency.MenuItem - Add to FileContext Menu
ThomasRambach
Advisor Advisor
ThomasRambach
I'm not sure why the VDF documentation is so slack compared to the normal API documentation but it is.
I'm looking for sample code on how to add a VDF.Forms.Currency.MenuItem to the FileContext menu. Any help would be appreciated.
Markus.Koechl
The SDK sample "JobProcessorApiSamples" has code that adds a command to the file context menu: QueuePublishJobCommandExtension.cs: Line 68ff. Does this help?
Markus Koechl
Solutions Engineer PDM, Autodesk Central Europe
ThomasRambach
@Markus.Koechl
I'm able to do that using the Autodesk.Connectivity.Explorer.Extensibility method.
It's my understanding that VDF is the only way possible to add custom context menus that contain sub-menus. ACEE only allows for flat structure. So, with that I have not seen any examples using VDF to add the menu to the file or item right click context menus.
