VB.net clean templates for Vault Client add-in?
christian_skare
christian_skare
When I've installed the SDK from "C:\Program Files\Autodesk\Vault Client 2024\SDK", it seems like only C# templates have been added to my template library in Visual Studio, is this correct?
It created this folder and files: C:\Program Files\Autodesk\Autodesk Vault 2024 SDK, which contains VB.net code.
How can I start a clean project with VB.net?
In one of the ReadMe.txt is says "Once the templates are copied over, restart or start a new instance of Visual Studio. The templates will now be available to select when creating
new projects, under the CSharp language.", which sounds like VB.net template doesn't exist?
Off topic, I've tried to build and manipulate the existing HelloWordVB (C:\Program Files\Autodesk\Autodesk Vault 2024 SDK\VS19\VB\HelloWorldVB) add-in, but during building I get an error:
Severity Code Description Project File Line Suppression State
Error The command "xcopy "I:\KAS programs\Vault Add-in\HelloWorldVB\..\..\..\..\bin\x64\AdskLicensingSDK_*.dll" "I:\KAS programs\Vault Add-in\HelloWorldVB\bin\x64\Release\" /y" exited with code 4. HelloWorldVB
Anyone know what causes this issue?
I've tried installing ADSKLicensing, but nothing seems to happen when I double click the installer (or run as admin).
Thanks for all the help! 🙂
Markus.Koechl
Indeed, the templates provided by the SDK are C# only.
The VB sample HelloWorld should build without error if you leave the post-build script as is.
Markus Koechl
Solutions Engineer PDM, Autodesk Central Europe
ChristianAndersenIsmyname
Thanks for the reply.
I’ve seen your name all over this forum, do you recall if this has been asked before? I couldn’t find any posts about vb.net templates.
The HelloWorldVB throw that error if I build it without any modifications to it. So I assume there is something I’ve missed to install.
edit: logged into my 2nd account, buts still me 🙂
