Vault - update UserDefinedProperties in files using API / C#
r_rybinskiA9RRF
r_rybinskiA9RRF
Hello Friends,
I come here with a problem I have been trying to solve for several days now. I want to automate filling UserDefinedProperties created for PDF files in Vault. I have a pretty big library with PDFs and CSV file with attributes that I want to inject into UDP in Vault.
I already managed to connect to Vault using C#, access folder with PDFs and list all filenames and Properties with values but I don't know how can I update them with my attributes. I already went through VaultSDK.chm but it didn't help much.
If you could share example code in C# / VB it would help me a lot.
Gabriel_Watson
jaapflonk
This is how i do it:
First i get a download ticket (you can alo use DocumentService.CheckoutFile
ByteArray ticket = documentService.GetDownloadTicketsByFileIds(new long[] { selectedFile.Id }).First();
Use the ticket to find the properties
            CtntSrcPropDef[] fileProps = Globals.Connection.WebServiceManager.FilestoreService.GetContentSourcePropertyDefinitions(
                ticket.Bytes, true);
Then i create PropWriteRequests
PropWriteRequests propWriteRequests = new PropWriteRequests();
            List<PropWriteReq> requests = new List<PropWriteReq>()
                new PropWriteReq()
                    CanCreate = true,
                    Moniker = "VltCategory!{D5CDD505-2E9C-101B-9397-08002B2CF9AE}!nvarchar", // Moniker van VltCategory property
                    Val = selectedFile.Cat.CatName
            propWriteRequests.Requests = requests.ToArray();
Then i use CopyFile and include the propWriteRequest
PropWriteResults propWriteResults = new PropWriteResults();
            byte[] uploadTicket = filestoreService.CopyFile(ticket.Bytes, extension, true, propWriteRequests, out propWriteResults);
And now use DocumentService.AddUploadedFile to upload the file with the new properties.
If you used CheckOut on step one can just check the file in.
            File newFile = documentService.AddUploadedFile(targetFolderId, tempFileName, "Temporary copy design for Flatten command", selectedFile.ModDate, null, bom, selectedFile.FileClass, false, uploadByteArray);
More information can be found here:
https://justonesandzeros.typepad.com/blog/2015/02/another-way-to-update-properties.html
Good luck
r_rybinskiA9RRF
Thank you Gabriel, I found solution in one of your link.
