Vault Thin Client Customization
Littlerubarb
Message 1 of 10
Littlerubarb
Good Day, I am looking for assistance in locating a div setting for help_wrapper...
Here's is the setting = <div class="help_wrapper" data-original-height="256" style="height: auto;">
I'm trying to set the thin client help default to closed - I have was hopping that someone could point me to the specific css,xml or cshtml that has this setting. I've had good luck in customizing the thin client via these files n the past and know that the setting is coming from somewhere, but so far I have had no luck in locating it.
Vault 2016 - Thin Client.
Replies (9)
Message 2 of 10
Littlerubarb
Never Mind  Found it...HelpPane.cshtml
Message 3 of 10
Littlerubarb
Ok changing this setting to 0 does not work, I ended up removing the panels from GettingStarted.cshtml. If anyone has an idea to force close the help panellet me know..
Message 4 of 10
radu1234
Have you been able in your customization to select and download multiple files at once?
Thank you for any suggestion you may have.
radu
Message 5 of 10
Littlerubarb
Not as of Yet, hoping for a web client change that would enable this function.
Message 6 of 10
radu1234
Message 7 of 10
Message 8 of 10
radu1234
What exactly are these links? what do they do? It's a little bit unclear in the article.
Also, it's not that simple to install it.
thank you.
Message 9 of 10
That are hyperlinks. It allows you to use them outside of the Vault. The link opens the Vault ThinClinent (of course you need a vault account, but no licence for read only!) and jumps the file into the Vault.  The example writes the hyperlink in a new property field inside the Vault. The next step after for example could be an export to ERP.
If you only use the Vault build in menu-command "Create hyperlink" you get another link - only using by Vault Explorer!
Message 10 of 10
Littlerubarb
Here's another meta link solution.. I worte it for batch exports...
https://apps.autodesk.com/VLTC/en/Detail/Index?id=5830027636072624347&appLang=en&os=Win32_64
