With one of the suggestions I've also tried to connect using WebServiceManager - I just want to query Vault Database -with no luck.
I can successfully connect using .NET Framework 4.7 Console App but if I try to do the same thing in ASP.NET ( using the same .NET Framework 4.7 ) it throws this error.
Server Error in '/' Application.
Could not load file or assembly 'Autodesk.Connectivity.WebServices.Interop' or one of its dependencies.
Description: An unhandled exception occurred during the execution of the current web request. Please review the stack trace for more information about the error and where it originated in the code.
Exception Details: System.BadImageFormatException: Could not load file or assembly 'Autodesk.Connectivity.WebServices.Interop' or one of its dependencies.
Source Error:
An unhandled exception was generated during the execution of the current web request. Information regarding the origin and location of the exception can be identified using the exception stack trace below.
Assembly Load Trace: The following information can be helpful to determine why the assembly 'Autodesk.Connectivity.WebServices.Interop' could not be loaded.
=== Pre-bind state information ===
LOG: DisplayName = Autodesk.Connectivity.WebServices.Interop
(Partial)
WRN: Partial binding information was supplied for an assembly:
WRN: Assembly Name: Autodesk.Connectivity.WebServices.Interop | Domain ID: 2
WRN: A partial bind occurs when only part of the assembly display name is provided.
WRN: This might result in the binder loading an incorrect assembly.
WRN: It is recommended to provide a fully specified textual identity for the assembly,
WRN: that consists of the simple name, version, culture, and public key token.
WRN: See whitepaper http://go.microsoft.com/fwlink/?LinkId=109270 for more information and common solutions to this issue.
LOG: Appbase = file:///C:/Users/***/source/repos/WebApplication33/
LOG: Initial PrivatePath = C:\Users\***\source\repos\WebApplication33\bin
Calling assembly : (Unknown).
LOG: This bind starts in default load context.
LOG: Using application configuration file: C:\Users\***\source\repos\WebApplication33\web.config
LOG: Using host configuration file: C:\Users\***\OneDrive\Dokumenty\IISExpress\config\aspnet.config
LOG: Using machine configuration file from C:\Windows\Microsoft.NET\Framework\v4.0.30319\config\machine.config.
LOG: Policy not being applied to reference at this time (private, custom, partial, or location-based assembly bind).
LOG: Attempting download of new URL file:///C:/Users/***/AppData/Local/Temp/Temporary ASP.NET Files/vs/f078ab58/e2fab317/Autodesk.Connectivity.WebServices.Interop.DLL.
LOG: Attempting download of new URL file:///C:/Users/***/AppData/Local/Temp/Temporary ASP.NET Files/vs/f078ab58/e2fab317/Autodesk.Connectivity.WebServices.Interop/Autodesk.Connectivity.WebServices.Interop.DLL.
LOG: Attempting download of new URL file:///C:/Users/***/source/repos/WebApplication33/bin/Autodesk.Connectivity.WebServices.Interop.DLL.
ERR: Failed to complete setup of assembly (hr = 0x8007000b). Probing terminated.
Stack Trace:
[BadImageFormatException: Could not load file or assembly 'Autodesk.Connectivity.WebServices.Interop' or one of its dependencies.]
System.Reflection.RuntimeAssembly._nLoad(AssemblyName fileName, String codeBase, Evidence assemblySecurity, RuntimeAssembly locationHint, StackCrawlMark& stackMark, IntPtr pPrivHostBinder, Boolean throwOnFileNotFound, Boolean forIntrospection, Boolean suppressSecurityChecks) +0
System.Reflection.RuntimeAssembly.nLoad(AssemblyName fileName, String codeBase, Evidence assemblySecurity, RuntimeAssembly locationHint, StackCrawlMark& stackMark, IntPtr pPrivHostBinder, Boolean throwOnFileNotFound, Boolean forIntrospection, Boolean suppressSecurityChecks) +36
System.Reflection.RuntimeAssembly.InternalLoadAssemblyName(AssemblyName assemblyRef, Evidence assemblySecurity, RuntimeAssembly reqAssembly, StackCrawlMark& stackMark, IntPtr pPrivHostBinder, Boolean throwOnFileNotFound, Boolean forIntrospection, Boolean suppressSecurityChecks) +152
System.Reflection.RuntimeAssembly.InternalLoad(String assemblyString, Evidence assemblySecurity, StackCrawlMark& stackMark, IntPtr pPrivHostBinder, Boolean forIntrospection) +77
System.Reflection.RuntimeAssembly.InternalLoad(String assemblyString, Evidence assemblySecurity, StackCrawlMark& stackMark, Boolean forIntrospection) +21
System.Reflection.Assembly.Load(String assemblyString) +28
System.Web.Configuration.CompilationSection.LoadAssemblyHelper(String assemblyName, Boolean starDirective) +38
[ConfigurationErrorsException: Could not load file or assembly 'Autodesk.Connectivity.WebServices.Interop' or one of its dependencies.]
System.Web.Configuration.CompilationSection.LoadAssemblyHelper(String assemblyName, Boolean starDirective) +738
System.Web.Configuration.CompilationSection.LoadAllAssembliesFromAppDomainBinDirectory() +217
System.Web.Configuration.CompilationSection.LoadAssembly(AssemblyInfo ai) +130
System.Web.Compilation.BuildManager.GetReferencedAssemblies(CompilationSection compConfig) +170
System.Web.Compilation.BuildManager.GetPreStartInitMethodsFromReferencedAssemblies() +92
System.Web.Compilation.BuildManager.CallPreStartInitMethods(String preStartInitListPath, Boolean& isRefAssemblyLoaded) +290
System.Web.Compilation.BuildManager.ExecutePreAppStart() +157
System.Web.Hosting.HostingEnvironment.Initialize(ApplicationManager appManager, IApplicationHost appHost, IConfigMapPathFactory configMapPathFactory, HostingEnvironmentParameters hostingParameters, PolicyLevel policyLevel, Exception appDomainCreationException) +549
[HttpException (0x80004005): Could not load file or assembly 'Autodesk.Connectivity.WebServices.Interop' or one of its dependencies.]
System.Web.HttpRuntime.FirstRequestInit(HttpContext context) +10075108
System.Web.HttpRuntime.EnsureFirstRequestInit(HttpContext context) +95
System.Web.HttpRuntime.ProcessRequestNotificationPrivate(IIS7WorkerRequest wr, HttpContext context) +254
Any ideas what can cause this ? It's the same framework...
