Vault Job Processor added programmatically
alder_moriggi
alder_moriggi
Hi all, I have a problem with a job added programmatically in Job Processor (Vault Workgroup 2019).
The job is added correctly in the Vault job queue (below I reported the instructions used):
But when the Job Processor runs it doesn't work correctly.
The following messages are reported in the job processor log file
General 29/12/2020 11:47:22
An item with the same key has already been added.
Unable to update job success/failure
The Job is "in processing" but it is not completed.
Any suggestions?
TIA
Alder
alder_moriggi
OK, I solved it.
I replace
m_Active_Connection.WebServiceManager.JobService.AddJob(l_Job_Name, l_Job_Name & ":" & Row.Cells(l_File_Field).Value.ToString(), l_JobParams.ToArray(), 100)
with
m_Active_Connection.WebServiceManager.JobService.AddJob(l_Job_Name, l_Job_Name & ":" & Row.Cells(l_File_Field).Value.ToString(), New JobParam() {l_JobParam_1, l_JobParam_2}, 100)
and everythings work fine
