Vault extension update
laurence.roijackers
laurence.roijackers
For Inventor, I created an AddIn that I let automatically update by an other AddIn.
I do this by have the "update AddIn" start automatically and look through the AddIns. Then I let it first perform an update on the actual addin and after that active it.
Sample:
For Each InventorAddIn As ApplicationAddIn In Addins
If InventorAddIn.ClientId = "TargetAddInClientId" Then
UpdateAddIn
InventorAddIn.Activate()
Next
This works well, as it is updates at the start of Inventor.
However, when I try the same trick in Vault, there doesn't seem to be any way to manage AddIns, or extensions, as it's called in Vault.
When I search a bit, the only idea I can find is to kill Vault on start to perform an update, https://forums.autodesk.com/t5/vault-customization/killing-vault-on-onstartup-when-needed/td-p/96582...
This could work, but are there other ways? Does anyone has ideas?
g.georgiades
I do the same thing but a different way - all users get a simple addin installed during vault upgrades which checks for updates and loads the main extension so that way I don't have to push to all user individually, I just have to update one server location that the extension reads from.
For vault and inventor, instead of writing them as a normal addin, I load the main content and pass the API methods to it. Here is a sample of my loader vault extension.
The downside to this method, is that the user cannot easily unload the extension from inventor (vault cannot unload anyways), but that is not an issue for me.
The other tricky part is updating the loader extension if needed, but that is a separate matter, and should not really need to happen.
using System.Collections.Generic;
using System.Diagnostics;
using System.Globalization;
using System.IO;
using System.Reflection;
using System.Threading;
using Autodesk.Connectivity.Explorer.Extensibility;
using Autodesk.Connectivity.Extensibility.Framework;
[assembly: ApiVersion("18.0")] //15=vault2022, 16=vault 2023, 18 = vault 2025
[assembly: ExtensionId("da91ef70-50cd-48d2-a38a-5ccc8415493f")]
namespace VaultExtension
    public class VaultExtension : IExplorerExtension
        public VaultExtension()
            Debug.Print("Vault extension loading");
        public IExplorerExtension content;
        public void OnStartup(IApplication application)
			//Directory structure is
			//	VaultExtension
			//		VaultExtension.dll
			//		VaultExtensionContent
			//			VaultExtensionContent.dll
            string loc = GetType().Assembly.Location; // gets the addin dll path
            string sourceDirectory = Path.GetDirectoryName(loc);
            string targetDirectory = Path.Combine(sourceDirectory, "VaultExtensionContent");
            string targetDll = Path.Combine(targetDirectory, "VaultExtensionContent.dll");
            var vltprocs = Process.GetProcessesByName("Connectivity.VaultPro");
            if(vltprocs.Length == 1)
                //update the content assembly from the server or whatever.
				//if more than 1 vault instance is running, then we won't be able to update as the dll will be locked. We can just wait until next time.
            try
                if(System.IO.File.Exists(targetDll))
                    var contentAssembly = Assembly.LoadFrom(targetDll); // loadfrom will load dependency dlls that are in the same dir, loadfile does not
                    content = (IExplorerExtension)contentAssembly.CreateInstance("VaultExtension.VaultExtensionContent", true, default, default, new object[] { application }, CultureInfo.CurrentCulture, default);
                    content?.OnStartup(application);
            catch
                System.Threading.ThreadPool.QueueUserWorkItem(_ => MessageBox.Show("Could Not Load VaultExtension Content Assembly!", "VaultExtension Load Error", MessageBoxButtons.OK, MessageBoxIcon.Warning, MessageBoxDefaultButton.Button1, MessageBoxOptions.DefaultDesktopOnly));
                return;
		//pass all the extension methods to the content assembly
        public void OnLogOn(IApplication application)
            content?.OnLogOn(application);
        public IEnumerable<CommandSite> CommandSites()
            return content?.CommandSites();
        public IEnumerable<string> HiddenCommands()
            return content?.HiddenCommands();
        public void OnShutdown(IApplication application)
            content?.OnShutdown(application);
        public void OnLogOff(IApplication application)
            content?.OnLogOff(application);
        public IEnumerable<DetailPaneTab> DetailTabs()
            return content?.DetailTabs();
        public IEnumerable<CustomEntityHandler> CustomEntityHandlers()
            return content?.CustomEntityHandlers();
