Vault Data Standard Inventor Property
m_hermann
Message 1 of 8
m_hermann
is there a chance to use non vault- mapped iProperties in the data standards dialog?
F.e. iProperty 'colour'  isn't mapped to vault but in use for BOM. Now, user has to fill it manually in the standard iProperties- dialog after data standards dialog has closed.
Replies (7)
Message 2 of 8
wangdu
Customize your xaml by adding a label and a textbox/combobox and have it bind to the property that you want to see in the dialog. Follow this documentation on how to do it.
Configure the Data Standard Dialog
Hope it helps!
Wangdu
coolOrange
www.coolOrange.com
Message 3 of 8
m_hermann
That's it.
Sorry, Didn't find the page myself, my search was not correct.
Now It works, many thanks.
Michael
Message 4 of 8
m_hermann
sorry for questioning again. But it will only work if i have a mapping from Inventor to Vault.
But i don't want to use the property in Vault, so i don't map it.
Message 5 of 8
wangdu
What have you done to have it shown on the dialog?
Place your property (label and textbox) to the left of the VDS dialog (General properties data grid and not the dynamic properties data grid.)
In case if you have something to share (non confidential) then I can give a look at it.
Wangdu
coolOrange
www.coolOrange.com
Message 6 of 8
m_hermann
here are my configurations
Message 7 of 8
wangdu
I have given a look at your configurations/dialog. In Vault I have removed the mapping on the description property to the Inventor.
And It is still working: working for me means when I close VDS dialog, then I check the iproperties and see the changes in the description property.
Let me know if you still have issues and possibly with a video or screen shots of the issue that you are facing.
Hope it helps!
Wangdu
coolOrange
www.coolOrange.com
Message 8 of 8
m_hermann
it Works, but only if i do not use dynamic properties - but thats ok.
