Vault Data Standard help with on selection change
adam_butcher
Message 1 of 1
adam_butcher
Hi Guys
I have a Property called group with a value of TEST 1 TEST 2 and TEST 3, Once test 1 is selected properties QIS 1 to QIS 8 must display information, if TEST 2 is selected QIS 1 to QIS 8 must display different values. This work when i change the category but i want it to work with the group property. Please see below.
Adam.
function InitializeWindow{
#begin rules applying commonly
$dsWindow.Title = SetWindowTitle
InitializeCategory
InitializeNumSchm
InitializeBreadCrumb
InitializeFileNameValidation
mGetProjectFolderPropToCADFile -mFolderSourcePropertyName "Name" -mCadFileTargetPropertyName "Project"
#end rules applying commonly
$mWindowName = $dsWindow.Name
switch($mWindowName)
"InventorWindow"
$Prop["Group"].add_PropertyChanged({
if ($_.PropertyName -eq "Value")
FilterQISProperties
function FilterQISProperties
$global:propDefs = $vault.PropertyService.GetPropertyDefinitionsByEntityClassId("FLDR")
if($Prop["Group"].Value -eq "TEST 1")
$Prop["QIS 1"].ListValues = @("-","1","2")
$Prop["QIS 2"].ListValues = @("-","1","2")
$Prop["QIS 3"].ListValues = @("-","1","2")
$Prop["QIS 4"].ListValues = @("-","1","2")
$Prop["QIS 5"].ListValues = @("-","1","2")
$Prop["QIS 6"].ListValues = @("-","1","2")
$Prop["QIS 7"].ListValues = @("-","1","2")
$Prop["QIS 8"].ListValues = @("-","1","2")
elseif($Prop["Group"].Value -eq "TEST 2")
$Prop["QIS 1"].ListValues = @("-","3","4")
$Prop["QIS 2"].ListValues = @("-","3","4")
$Prop["QIS 3"].ListValues = @("-","3","4")
$Prop["QIS 4"].ListValues = @("-","3","4")
$Prop["QIS 5"].ListValues = @("-","3","4")
$Prop["QIS 6"].ListValues = @("-","3","4")
$Prop["QIS 7"].ListValues = @("-","3","4")
$Prop["QIS 8"].ListValues = @("-","3","4")
elseif($Prop["Group"].Value -eq "TEST 3")
$Prop["QIS 1"].ListValues = @("-","5","6")
$Prop["QIS 2"].ListValues = @("-","5","6")
$Prop["QIS 3"].ListValues = @("-","5","6")
$Prop["QIS 4"].ListValues = @("-","5","6")
$Prop["QIS 5"].ListValues = @("-","5","6")
$Prop["QIS 6"].ListValues = @("-","5","6")
$Prop["QIS 7"].ListValues = @("-","5","6")
$Prop["QIS 8"].ListValues = @("-","5","6")
return $properties
Replies (0)
