Vault Data Standard 2015 R2 - set file category automatically
Rproehl
Rproehl
I'd like to set the category of an Excel file automatically related to the folder where it will be created (or it is stored).
e.g.
I have
-folder1
-folder2
-folder3
for each folder I have a catogory (e.g. categoryf1, categoryf2, categoryf3)
creating a new file in folder1 should set the category to categoryf1.
using
if ($_fl1 -eq "folder1")
$Prop[_Category].Value = "categoryf1"
within the function InitializeWindow
will stop the functionality (no UI window pops up).
in the xaml-file I've added
<TextBox x:Name="txtCategory2" Text="{Binding Prop[_Category].Value}"/>
I've removed the default ComboBox (which is part of the file.xaml) for selecting the category.
I hope it is just a little thing to modify - many thanks for your help
BR
Rainer
wangdu
Hi Rainer,
In the script you have posted, double quotes in the indexer is missing.
$Prop["_Category"].Value = "categoryf1"
Does that help you?
HTH
Wangdu
www.coolOrange.com
Rproehl
Thank u very much - after sitting days in front of these editor I'm getting blind.
It works now Smiley Embarassed
