Vault customization in .net - namespace error
I am upgrading Vault 2014 to Vault 2017. I am working on vault Add ins in .net.
Please let me know what is the replacement for Autodesk.Connectivity.Webservices.FixedLycycDef() GetAllLifeCycleDefinitons
Is this what you're looking for?
var docservEx = Connection.WebServiceManager.DocumentServiceExtensions;
            Autodesk.Connectivity.WebServices.LfCycDef[] LifeCycleArray = docservEx.GetAllLifeCycleDefinitions();
Thanks for your reply.
Could you please help me with the code below. I am getting error on the line highlighted in red, Idpair and GetLifeCycleStateIdsByFileMasterIds were in the namespace for Vault 2014 but no longer exist in Vault 2017. what would be the replacement for this code. TIA
public void ChangeState(List<long> selectedMasterFileIds, string projectValue, long releaseState)
try
List<File> updatedFileIds = new List<File>();
List<long> filesWithNoOrDifferentLifecycle = new List<long>();
List<long> filesWithBasicLifecycle = new List<long>();
IdPair[] states = util.DocSvcExt.GetLifeCycleStateIdsByFileMasterIds(selectedMasterFileIds.ToArray());
foreach (IdPair idpair in states)
if (util.FileLifeCycleStateMap().ContainsKey(idpair.ValId))
filesWithBasicLifecycle.Add(idpair.EntityId);
else
filesWithNoOrDifferentLifecycle.Add(idpair.EntityId);
long[] lifecycleStateIds = new long[filesWithNoOrDifferentLifecycle.Count];
long[] lifecycleDefinitionIds = new long[filesWithNoOrDifferentLifecycle.Count];
File[] newVersions = new File[0];
File[] moreNewVersions = new File[0];
if (filesWithNoOrDifferentLifecycle.Count > 0)
#region updating files that don't have a lifecycle definition or have a different one from the basic
for (int z = 0; z < lifecycleStateIds.Length; z++)
lifecycleStateIds[z] = releaseState;
lifecycleDefinitionIds[z] = util.FileLifeCycleDefinitionMap()["Project Design Lifecycle"].Id;
newVersions = util.DocSvcExt.UpdateFileLifeCycleDefinitions(filesWithNoOrDifferentLifecycle.ToArray(), lifecycleDefinitionIds, lifecycleStateIds, projectValue);
#endregion
if (filesWithBasicLifecycle.Count > 0)
#region updating files that already belong to the basic lifecycle definition or have a different one from the basic
lifecycleStateIds = new long[filesWithBasicLifecycle.Count];
moreNewVersions = util.DocSvcExt.UpdateFileLifeCycleStates(filesWithBasicLifecycle.ToArray(), lifecycleStateIds, projectValue);
#endregion
Please see my code below using Vault 2014. I am getting error on the line highlighted in red. Idpair and GetLifeCycleStateIdsByFileMasterIds does not exist in Vault 2017 namespaces. What would be the replacement code for this. TIA
try
else
#endregion
#endregion
I'm sorry. I misread your question. I haven't upgraded to Vault 2017 yet, so I can't look it up.
If I did have it installed, I'd be looking in the Vault SDK documentation for 2017 (It comes with the install and ends up here: C:\Program Files\Autodesk\Vault Professional 2017\SDK\)? Usually if they deprecate something, they indicate a replacement. My guess is you already tried this.
For what it's worth, I never knew this idpair option existed. We just use the command I mentioned above and then get the state for each file. Wish I knew about this feature...before they got rid of it, that is.
psaarloos
You should be able to build such a lookup list yourself using Linq. Here is a sample (haven't tested it). You'll need to pass in an array with masterIds.
FileArray[] fileArray = VaultCom.Connection.WebServiceManager.DocumentService.GetFilesByMasterIds(new long[] { fileMasterIds });
            Dictionary<long, long> demo = new Dictionary<long, long>();
            demo = fileArray[0].Files.Select(x => new { x.MasterId, x.FileLfCyc.LfCycStateId }).ToDictionary(x => x.MasterId, x => x.LfCycStateId);
Hope it helps!
Pim Saarloos
Product Manager
If my post answers your question, please click the "Accept as Solution" button. Kudos are much appreciated!
Thanks for your reply. I was thinking about the same solution. I will try to implement this and see if it works out.
