Vault API - after renaming files the links are broken
I have renamed files in vault with this code (obtained here). But now the links are broken. What I have missed and is it possible to create the lost links again?
File checkedOutNewFile = CheckOut(folders[0], selectedFile);
if (checkedOutNewFile != null)
CheckIn(folders[0], checkedOutNewFile, newname, Coment);
public File CheckOut(Folder folder, File file)
string localPath = _connection.WorkingFoldersManager.GetWorkingFolder(folder.FullName).FullPath;
if (!System.IO.Directory.Exists(localPath))
System.IO.Directory.CreateDirectory(localPath);
AcquireFilesSettings settings = new VDF.Vault.Settings.AcquireFilesSettings(_connection);
settings.OptionsRelationshipGathering.FileRelationshipSettings.VersionGatheringOption = Autodesk.DataManagement.Client.Framework.Vault.Currency.VersionGatheringOption.Latest;
settings.OptionsResolution.OverwriteOption = AcquireFilesSettings.AcquireFileResolutionOptions.OverwriteOptions.ForceOverwriteAll;
settings.LocalPath = new VDF.Currency.FolderPathAbsolute(localPath);
settings.AddFileToAcquire(
new VDF.Vault.Currency.Entities.FileIteration(_connection, file),
VDF.Vault.Settings.AcquireFilesSettings.AcquisitionOption.Download | VDF.Vault.Settings.AcquireFilesSettings.AcquisitionOption.Checkout);
VDF.Vault.Results.AcquireFilesResults result = _connection.FileManager.AcquireFiles(settings);
foreach (var r in result.FileResults)
return m_serviceManager.DocumentService.GetFileById(r.File.EntityIterationId);
public File CheckIn(Folder folder, File file, string newname,string comm)
string filePath = System.IO.Path.Combine(localPath, file.Name);
VDF.Vault.Currency.Entities.FileIteration ff = _connection.FileManager.CheckinFile(
new VDF.Vault.Currency.Entities.FileIteration(_connection, file), comm, false, null, null,
true, newname, file.FileClass, false,
new VDF.Currency.FilePathAbsolute(filePath));
return m_serviceManager.DocumentService.GetFileById(ff.EntityIterationId);
orbjeff
Hi there,
The fourth parameter in your "CheckinFile" method is the associations array. In your code you are defining this parameter as null (no references/links) which is why your files no longer have the links. You need to capture the association array from the checked out file and use it when checking the file back in.
I had this problem a few years ago and while there may be other options with the new Vault API the idea is still the same. See here:
http://forums.autodesk.com/t5/vault-customization/maintaining-existing-file-attachments-after-checki...
It's not something that is easily fixed to my knowledge so hopefully you discovered this on a development Vault.
Jeff Johnson
Technical Consultant
MasterGraphics Inc.
Thank you, Jeff.
