Vault 2017 Web App Log In issue
Hi All,
I'm having a bit of trouble logging in to the Vault from a web application.
I found a post on the forum explaining how to solve the problem but for some reason it's not working for me.
Older post on the forum: Older Post Vault Web App Login Issue
I will try to explain the steps I've followed to solve the problem, and what the issue is.
1. Started a new project in Visual Basic 2015 - ASP.NET Web Application (.NET Framework)
2. Created a new Web Form "Default.aspx" and made some controls (textbox and buttons to mimic the vault login form).
The code behind this form (just the login action):
using System; using VDF = Autodesk.DataManagement.Client.Framework; namespace VaultWebApplication.web_forms { public partial class Default : System.Web.UI.Page { protected void Page_Load(object sender, EventArgs e) { } protected void submitEventMethod(object sender, EventArgs e) { try { VDF.Vault.Results.LogInResult results = VDF.Vault.Library.ConnectionManager.LogIn(serverTextBox.Text, vaultTextBox.Text, usernameTextBox.Text, passwordTextBox.Text, VDF.Vault.Currency.Connections.AuthenticationFlags.ReadOnly, null); resultTextBox.Text = results.Success.ToString(); } catch (Exception ex) { resultTextBox.Text = "Error: " + ex.Message.ToString(); } } } }
3. I've made a Global.asax with code behind:
using System; using System.Globalization; using System.Text.RegularExpressions; using Autodesk.Connectivity.WebServices; using Autodesk.Connectivity.WebServicesTools; using System.Reflection; namespace VaultWebApplication { public class WebApiApplication : System.Web.HttpApplication { #region Assembly Resolver private static Regex assemblyRegEx; private static bool Is64Process = false; static WebApiApplication() { Is64Process = IntPtr.Size == 8; InitRegEx(); AppDomain.CurrentDomain.AssemblyResolve += CurrentDomain_AssemblyResolve; } private static Assembly CurrentDomain_AssemblyResolve(object sender, ResolveEventArgs args) { if (IsXmlSerializer(args.Name)) { return null; } string[] fields = args.Name.Split(','); string assName = fields[0]; if (assName.EndsWith(".resources", StringComparison.InvariantCultureIgnoreCase)) { return null; } Assembly ass = null; try { // First try to locate the assembly in the list of loaded assembly of the current AppDomain AssemblyName name = new AssemblyName(args.Name); Assembly[] assemblies = AppDomain.CurrentDomain.GetAssemblies(); foreach (Assembly assembly in assemblies) { if (name.Name == assembly.GetName().Name) { return assembly; } } ass = Assembly.LoadFrom(args.Name); } catch { // Try to locate the assembly in the directory that contains the AddIn type. string basePath = System.IO.Path.GetDirectoryName(new Uri(MethodBase.GetCurrentMethod().DeclaringType.Assembly.CodeBase).LocalPath); string subFolder = Is64Process ? "x64" : "x86"; string assemblyFileName = System.IO.Path.Combine(basePath, string.Format(CultureInfo.InvariantCulture, "{1}\\{0}.dll", new AssemblyName(args.Name).Name, subFolder)); if(System.IO.File.Exists(assemblyFileName)) { ass = Assembly.LoadFile(assemblyFileName); } else { string fout = new AssemblyName(args.Name).Name; } } finally { } return ass; } private static void InitRegEx() { string regex = @"^([\w\.]+)XmlSerializers"; RegexOptions options = ((RegexOptions.IgnorePatternWhitespace | RegexOptions.Multiline) | RegexOptions.IgnoreCase); assemblyRegEx = new Regex(regex, options); } private static Boolean IsXmlSerializer(string name) { return assemblyRegEx.IsMatch(name); } #endregion protected void Application_Start(object sender, EventArgs e) { //Active License WebServiceManager.AllowUI = false; LicenseManager.Instance.SetActive(); } } }
4. Made a "x64" and "x86" folder in the project and added the necessary .dll's in the folders
5. Added the clmloader.dll to my debugfolder
6. In the web.config file
<?xml version="1.0" encoding="utf-8"?> <!-- For more information on how to configure your ASP.NET application, please visit http://go.microsoft.com/fwlink/?LinkId=169433 --> <configuration> <configSections> <section name="Licensing" type="Autodesk.Connectivity.WebServices.LicensingSection, Autodesk.Connectivity.WebServices" /> </configSections> <system.web> <compilation debug="true" targetFramework="4.5"/> <httpRuntime targetFramework="4.5"/> <identity impersonate="false"/> <customErrors mode="Off"/> </system.web> <Licensing edition="professional"/> </configuration>
7. Add User to the IIS application pool and opened a Vault Client with the same user cred's
8. The vault user I use to try to login has Admin rights
But when I try this I get this as exception message:
"de type-initialisatiefunctie voor autodesk.connectivity.webservicestools.webservicemanager heeft een uitzondering veroorzaakt."
rough translation:
"the type of initialisation function for autodesk.connectivity.webservicestools.webservicemanager has caused an execption."
Can someone help me with this?
Thanks in advance
