Unhandled error when retrieving item BOM in Vault 2013
I have code that accesses the item BOM as follows:
if (itemLifeCycleState == "Work In Progress")
bom = _svc.ItemService.GetItemBOMByItemIdAndDate(itemId, itemEffStart, BOMTyp.Tip, BOMViewEditOptions.Defaults);
else //Obsolete or Released (In Review is not applicable)
bom = _svc.ItemService.GetItemBOMByItemIdAndDate(itemId, DateTime.Now, BOMTyp.Effective, BOMViewEditOptions.Defaults);
The code compiled with the Vault 2012 DLLs works fine against a Vault 2012 repository . But the same EXE generates an unhandled exception when running against a Vault 2013 repository. The data on the 2013 server was restored from a backup of the 2012 server. The exception occurs when the code attempts to retrieve the BOM of an Obsolete item.
I ran into the same exception when testing code against data created in Vault 2013. Unfortunately, I don't recall the exact circumstances except that the item was Obsolete.
I will try to recreate the issue in 2013. In the meantime, I'd really appreciate any suggestions on how get around this.
Thanks.
F.
Redmond.D
First you need to handle the exception with a catch block.  That will give you more information such as the exception type, error code, and the line of code that is failing.
Doug Redmond
Software Engineer
Autodesk, Inc.
The error occurs on the line:
The exception message is:
Unhandled Exception: System.Web.Services.Protocols.SoapException: System.Web.Services.Protocols.SoapException: 1417
   at Autodesk.Connectivity.WebServices.ItemSvc._ItemService.Invoke(String methodName, Object[] parameters)
   at Autodesk.Connectivity.WebServices.ItemSvc._ItemService.GetItemBOMByItemIdAndDate(Int64 itemIterationId, DateTime dateOfInterest, BOMTyp type, BOMViewEditOptions options)
I am able to reproduce this error with a small test Vault. Let me know if you'd like a copy. Thanks.
F.
