Unable to Check out file
sathishkannan41
sathishkannan41
I'm getting the attached error message when I try to check out this file.
This is a Inventor drawing file, I can checkout the .ipt file used in this drawing but not the .idw file.
I tried to GET file and checkout using Inventor Vault Addin, that too didn't help.
I'm using Vault professional 2018 and it's updated with Vault 2018.2 update.
OS: Windows 7, 64-Bit.
Someone help me to solve this issue.
Sathish
Balaji_07
Hi Satish,
Kindly refer this below link
https://knowledge.autodesk.com/support/vault-products/troubleshooting/caas/sfdcarticles/sfdcarticles...
Hope it helps.
Cheers 🙂
Balaji A
Accept this post as Solution if  you found it useful and do not forget to hit Kudos!
sathishkannan41
The file had ownership issue. Transfer of ownership fixed it.
Sathish
