Suppress Commands by User Groups
KenFoysterWSP
KenFoysterWSP
Hi, I am inquiring if possible and if anyone has suppress vault commands by Vault user groups.
Add to the following text in the MenuDefinitions.xml or other format?
<SuppressMenuItems>
NewFolder,NewFolderGroupMenu,NewFolderGroupButton,NewFolderForContextMenus
</SuppressMenuItems>
</mymenu>
Markus.Koechl
You cannot suppress or grey out a command using Data Standard Menudefinition.xml. This setting is loaded during application (extension) start and is therefore static. However, you can restrict the command by validating the current user and exiting, or passing through the command execution. Find a sample here: VDS-Sample-Configurations-2025/VDS-PDMC-Sample-Vault/Vault.Custom/addinVault/Menus/ADSK.QS.ActivateS...
Markus Koechl
Solutions Engineer PDM, Autodesk Central Europe
