SQL Connection in Vault 2026 with .net 8
matt_mwe
matt_mwe
Hello everyone,
I'm struggling currently with migrating my Vault Add-In to .net 8
Especially with the task of migrating "System.Data.SQL".
I tried also the new "Microsoft.Data.SQL" but it always run in a "System.PlatformNotSupportedException: 'Microsoft.Data.SqlClient is not supported on this platform.'" error.
I also tried to fix from this post Solved: SQL Connection in AutoCAD 2025 - Autodesk Community, but it didn't work out for me.
What I tried so far:
- Adding <RuntimeIdentifier>win-x64</RuntimeIdentifier> in the Project file
- Putting all the DLL's next to the Addin DLL
- Trying it with the obsolete "System.Data.SQL" package
Does anyone have a working solution on that?
Nick_Hall
Hi Matt
I've just migrated a Vault add-in to 2026/.net 8, and I had to
  1. Use Microsoft.Data.Sqlclient
  2. Copy these files to the output folder
    %USERPROFILE%\.nuget\packages\microsoft.data.sqlclient.sni.runtime\6.0.2\runtimes\win-x64\native\Microsoft.Data.SqlClient.SNI.dll
    %USERPROFILE%\.nuget\packages\microsoft.data.sqlclient\6.0.2\runtimes\win\lib\net8.0\Microsoft.Data.SqlClient.dll
After that, everything worked fine.
Hope that helps
Nick
matt_mwe
Thank you very much!
This worked for me too.
@Nick_Hall: Could you provide any source, how you figured that out?
Nick_Hall
Hi Matt
I started with this search - "Microsoft.Data.SqlClient is not supported on this platform"- from one error message I got when debugging.
This led me to this article - https://learn.microsoft.com/en-us/answers/questions/1663112/microsoft-data-sqlclient-5-2-0-fails-to-...
There is a reply from Tacito Fieker (it's first when you order by "most helpful") which says
It was necessary to copy the file: "....nuget\packages\microsoft.data.sqlclient\5.2.2\runtimes\win\lib\net8.0\Microsft.Data.SQLClient.dll" to the BIN folder.
I also needed to copy: Microsoft.Data.SqlClient.SNI.dll & Microsoft.Identity.Client.dll
Then I dug around in %USERPROFILE%\.nuget and found the files I thought I would need. After some trial & error, I ended up with just the two I noted before.
It wasn't as quick as that description sounds, though. I went down the wrong path a few times before I got there.
Nick
matt_mwe
@Nick_Hall Thank you for providing that.
Interesting enough that you have to use the packages from the .nuget folder. I tried it with the DLL's from a dummy console application that referenced `Microsoft.Data.SqlClient` without success.
david.siegert63GB8
Hello @matt_mwe @Nick_Hall,
I found a cleaner solution and an explanation why Nicks solution works.
There are two things.
1) <CopyLocalLockFileAssemblies>true</CopyLocalLockFileAssemblies> add in your .csproj
 - OutputType Library by default does not copy dependencies to OutDir (Which makes sense, bcease this should only happen in the application that uses the library - there all dependencies should be copied). But because we build plugins, we need all dependencies with our library. This is what the Property CopyLocalLockFileAssemblies does.
 - There is also property EnableDynamicLoading, which does the same thing and a bit more: https://learn.microsoft.com/en-us/dotnet/core/project-sdk/msbuild-props#enabledynamicloading
2) <RuntimeIdentifier>win-x64</RuntimeIdentifier> add in your .csproj
When you reference a nuget like Microsoft.Data.SqlClient, which includes native and runtime platform specific dlls which are now (when we use CopyLocalLockFileAssemblies)copied to outdir\runtimes directory. We need to tell the compiler which runtime dlls to copy to outdir thats where RuntimeIdentifier comes in.
TLDR;
add this to your csproj
The result is that both dlls that Nick mentions in his solution are automatically copied to outdir.
Nick_Hall
Thanks, David, that's really useful to know.
It would be helpful to have this information in the Vault SDK Help. Maybe @Markus.Koechl can help with that?
Nick
