Announcements
Announcement: We’re aware of an issue affecting starting a new topic from category pages and creating new blog posts. New topics can still be started directly from the relevant board. Learn more here.
Splitting the numbering scheme on delimiters to use for property names
Kevin_DonovanATHFU
Kevin_DonovanATHFU
Apologies, I am new to Autodesk.
In AutoDesk vault 2025, using AutoCAD LT, I am trying to customise the datacard. My numbering scheme has a number defined with "-" as delimiters. An example number is: 039-211-CL-0001 and I want to split the number using the delimiters to display under individual property names as a property value. This is to enable it for report selection.
So far, I am trying to use the Default.ps1 file on the server with the following code and, as far as I can ascertain, I have included it in the GetNewFileName function:
# Read the final number produced by DSNumSchemeCtrl
        $gen = $filename
        #if ([string]::IsNullOrWhiteSpace($gen)) { return }
        # Split by delimiter
        $parts = $gen -split("-")
        # checks min 1 segment
        #if ($parts.Count -lt 1) { return }
        # Map segments -> category properties
        $Prop["KD Plant Area"].Value = $parts[0]
        $Prop["KD System Number"].Value = $parts[1]
        $Prop["KD Discipline"].Value = $parts[2]
        $Prop["KD Drawing Number "].Value = $parts[3]
        $Prop["KD Rev Number"].Value = $parts[4]
It does nothing for me. Is there anyone who has tried to do this before that can point me in the right direction?
Markus.Koechl
I validated your approach by changing the Default.ps1 function GetNewFileName like this:
So, you should be able to fill all your properties.
You wrote that you are "trying to use the Default.ps1 file on the server". I wonder what you meant by that, as Data Standard is a client extension located on your machine, running Vault Clients, in C:\ProgramData\Autodesk\Vault <version>\Extensions\DataStandard\.
Markus Koechl
Solutions Engineer PDM, Autodesk Central Europe
Kevin_DonovanATHFU
Thank you so much for your time Markus, I have been out of office for the last few days so I only have quickly looked at your solution.
I have been implementing my changes on our development server which has vault professional 2025 installed. If I manage to get this working, does that mean it needs to be installed on the desktops of all the people who have access to vault professional (it should only be 4 or 5 but some are in the UK and I am in Ireland). I assumed vault used a front end on the desktops.
Should I be replacing _XLTN_PARTNUMBER with anything or using that syntax elsewhere to populate my properties? I can't figure out the logic - I'm not that good a programmer!!
Markus.Koechl
Data Standard configurations must deploy to all clients. Best review and walk through the VDS Tutorial accessible in the Help: Vault Help | Vault Data Standard - Tutorial | Autodesk
You will need to repeat the step that I applied to the Part Number property for each of your properties.
Markus Koechl
Kevin_DonovanATHFU
Hi Markus, thanks again I will look through the training
Regards
Kev
