Setup of Solidworks Add-in for Vault Pro
dpeters1
dpeters1
I am trying to setup Vault Pro 2016 with the Solidworks Add-in, for use with Solidworks 2015 SP 4.0.
I am having trouble updating the property mapping to add SolidWorksPropertyProvider (*.sldprt;*.sldasm;*.slddrw) to Thumbnail and Type properties, as described in Step 7 in the ReadMe file under "Vault add-in for SolidWorks".  It is not appearing as an option under Provider.  Any suggestions?
Also, do you recommend importing properties from vault or a source file (Step 9)?
Thanks for the help.
Markus.Koechl
in general I prefer to use property import from Vault to set up mappings. This ensures, that property management on the server works properly. In your case - if the Solidworks property provider is not listed - I am quite sure, that the registration (installation) of the SolidWorks Server AddIn (ADMS extension) did not succeed. Would you mind to retry - and in case it does not work check the log files?
Markus
Markus Koechl
Solutions Engineer PDM, Autodesk Central Europe
upchurt
From what you desribe it sounds like you may need to install the server add-in to get SolidWorks listed in the provider list. Once this is installed thumbnails should be automatically mapped.
You can find the server addin here:
Autodesk Vault SolidWorks add-in
Please let us know if this helps.
Trent Upchurch
