Sending mail via API to Vault ADMS Server or Enterprise AddOdd (VAO)
kdaTZK4A
kdaTZK4A
Has anyone experience in sending email from VAULT API?
I am making a Custom Job for the Vault Job Procceser and want to send out an email on certain conditions.
In the docs for VAO i can see that I can send email notifications on Lifecycle transitions.
I would like to do it via API when certain condotions are true and be able to make a custom body in the email being send.
My ADMS has SMTP configured and is configured to send out notification. Is tested and works.
I found this:
using VDF = Autodesk.DataManagement.Client.Framework;
public JobOutcome Execute(IJobProcessorServices context, IJob job)
  string[] attacments = null;
  byte[][] fileContents = null;
  context.Connection.WebServiceManager.PackageService.SendEmail("sender-email", "receiver-email", "From Costum   Job", "News", attacments, fileContents);
Get this exception:
StackTrace = " at System.Runtime.Remoting.Proxies.RealProxy.HandleReturnMessage(IMessage reqMsg, IMessage retMsg)\r\n
at System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke(MessageData& msgData, Int32 type)\r\n
at Autodesk.Connectivity.WebServices.IPackageServ...
frank_willing
 the declaraition of
is wrong.
here my declarations (sorry but in vb.net):
' KORREKT: Ein leeres Array von Strings
Dim attachmentPaths() As String = New String() {}
' KORREKT: Ein leeres Array von Byte-Arrays
Dim attachmentContents()() As Byte = New Byte()() {}
after the change it worked.
also you changed sender and receiver.
regards Frank
