Search in Jobqueue
Search in Jobqueue
gbadziura
Search in Jobqueue
gbadziura
Hi All
is there a better way to find a Job of file in the Jobqueu. At the moment i use the somthing like this to find out if a Job for a file exist.
var dateiname = vaultDocument.File.Name.ToUpper();
var jobs = settingParameter.ConnectionManager.VaultConnection.WebServiceManager.JobService.GetJobsByDate(100000, DateTime.Today.AddDays(-100));
if (jobs != null && jobs.Any())
return jobs.All(job => !job.Descr.ToUpper().Contains(dateiname));
return true;
With this kind of search i can get more than i want or nothing if the FileName is not part of the Description. Does anyone know a better solution?
Thanks for any support.
regards
Gerhard
Markus.Koechl
In our Data Standard snippet JobListTab to display pending jobs for a selected file (posted here https://knowledge.autodesk.com/community/article/33706) we are handling this in the same way. However Vault default jobs always include the file name in the description, so custom jobs might have an issue if they don't add the file name or in case the vault is configured not to enforce unique names. Another good reason to enforce ;).
Markus Koechl
Solutions Engineer PDM, Autodesk Central Europe
gbadziura
Hi Markus
You are right. To enforce the unique filename might be an Option, but only if you dont' use Jobs für Items.
We use the Event UpdateItemLifecycleStateEvents to check various things. One is if  there exist an Job for the Item. So for example if there is an Job for the file '0815.idw' in the jobqueue and i check the Item number  '0815'  only in the description then i get a true.
Meanwhile i solved the problem for me with checking the JobParams. But in my opinion this should be an part of the API. Perhaps in the next version
regards
Gerhard
UweHandzik
Leider kann die VDS_JobListTab_2017.1. ZIP nicht geladen werden ..
<Error>
<Code>AccessDenied</Code>
<Message>Access Denied</Message>
<RequestId>9CE93D62A85D9C40</RequestId>
<HostId>
JaQZihJALXU2CKtkvznb0j1JZdxzb+KSB40RYD/n69WXJP/fBsNWjZMwCl6aAfKq6+zWbOfjGHk=
</HostId>
</Error>
Markus.Koechl
thanks for the hint. Please try again, the download link is updated.
Alternatively use (German AKN page): https://knowledge.autodesk.com/de/community/article/29071
Markus Koechl
TylerWarner33
Hello @Markus.Koechl , is there an updated link to the article mentioned?
Tyler
If this answered your question, click 'Accept Solution'.
If this was helpful, click 'Like'.
Tyler Warner
