Refreshing the Vault client.
pranit_awale
pranit_awale
Is there any API function to refresh the Vault Client (Explorer) from a standalone application? I explored the API but couldn’t find anything. Has anyone tried this before, and is there a way to achieve it?
Markus.Koechl
You would need to send the "F5" key to the application. Or - that's my preference - navigate to an entity. To do this call the Connectivity.VaultPro.exe with an *.acr file as argument.
The *.acr file content may look like this:
<?xml version="1.0" encoding="utf-8"?>
<ADM xmlns="http://schemas.autodesk.com/msd/plm/ExplorerAutomation/2004-11-01">
  <Server>localhost</Server>
  <Vault>PDMC-Sample</Vault>
  <Operations>
    <Operation ObjectType="File">
      <ObjectID>$/Designs/Inventor Sample Data/Car Seat/Car Seat.iam</ObjectID>
      <Command>Select</Command>
    </Operation>
  </Operations>
</ADM>
The command to invoke the Vault Explorer Client navigating to the given address in PowerShell:
	$acrFilePath = "C:\Users\Administrator\Downloads\FileCommandRequest.acr"
	# open the acr file in Vault Explorer; note-- this only works if the file extension *.acr is mapped to Connectivity.VaultPro.exe in Windows
		Invoke-Item $acrFilePath
If a Vault Client is up and running it will bring Vault Window to the front and navigate to the entity.
Alternatively instantiate a new Vault Client session if Vault Explorer is not open yet.
# run Connectivity.VaultPro.exe with the *acr as attribute
$vaultProPath = "C:\Program Files\Autodesk\Vault Client 2026\Explorer\Connectivity.VaultPro.exe"
$acrFilePath = "C:\Users\Administrator\Downloads\CustomObjectCommandRequest.acr"
if (Test-Path $vaultProPath) {
   & "$vaultProPath" /acr "$acrFilePath"
} else {
	Write-Error "VaultPro.exe not found at path: $vaultProPath"
The view is refreshed in any case.
I hope this helps.
Markus Koechl
Solutions Engineer PDM, Autodesk Central Europe
pranit_awale
sent the "F5" key to the application.
It's working well now .
Thank you @Markus.Koechl
