Possible bug or strange behavior: Recursion in DocumentService.GetFileDeleteRestrictionsByMasterId
thomas.behrendY5FX4
Message 1 of 1
thomas.behrendY5FX4
Hello again šŸ™‚
also described in the Recycle Bin idea threat, when I want to check of other Restrictions in the DocumentService.DeleteFileEvents Event I programmed myself, it wents into a recursion. Below a excerpt from my code without the fix.
If you don“t remove the event, it will call itself again and again.
using Autodesk.Connectivity.Extensibility.Framework;
using Autodesk.Connectivity.WebServices;
using System;
using System.Collections.Generic;
using System.Linq;
namespace MyVaultExtensions {
	public class MyVaultRestrictions : IWebServiceExtension {
		public void OnLoad() {
			DocumentService.DeleteFileEvents.GetRestrictions += new EventHandler<DeleteFileCommandEventArgs>(DeleteFileEvents_GetRestrictions);
		private void DeleteFileEvents_GetRestrictions(object sender, DeleteFileCommandEventArgs e) {
			var ds = (DocumentService)sender;
			// Check if Vault or other restrictions are found for the file, if so, don“t do anything
			var res = documentService.GetFileDeleteRestrictionsByMasterId(eventArgs.FileMasterIds.FirstOrDefault(), eventArgs.FolderId); // here he runs forever now
			/* the rest of your code will never be executed */
The fix is to remove the Event for the time of the check
I would rather not have to do such hacks, but I trust Vault that the restrictions from i.e. LifeCycles are working and my code should not run.
Any other suggestions?
Best regards
Thomas
Replies (0)
