.NET: Administrator Command in Non-Administrator Extension' context
glanard
glanard
Creating a custom command that, for example, add routing and add change order, that assumes the user context has administrator rights, right?
So, is it possible to force a custom command to have administrator rights even if the final user is not administrator in the Vaut client?
sajith_subramanian
Autodesk Support
Autodesk Support
Hi @glanard,
You cannot force your custom command into having admin rights. One way to probably achieve is by impersonation, i.e. logging in as admin user to perform the task and then logging out.
Please take a look at the below article which describes this in detail:
https://justonesandzeros.typepad.com/blog/2010/08/user-impersonation.html
Sajith
Sajith Subramanian
Autodesk Developer Network
