Load Vault Instance
Load Vault Instance
Load Vault Instance
I need to to load Vault from external application
I have a Windows application developed in C# for Vault 2014 which connects my Autodesk Inventor and Outlook to Vault after verifying and perfomring some operation.
I need to load a instance of Autodesk Vault from outlook when an event is triggered. If there is a vault running then use the same. how can i do this.
Assuming your using the 2014 vault API , use Connectivity.InventorAddin.EdmAddin.EdmSecurity to get a Connection instance from Inventor.
