Jobprocessor Delegate Host RAM usage, release of InventorObject
jan.wagnerRB67Z
Message 3 of 9
jan.wagnerRB67Z
Hi all,
In Vault Professional 2025 I created a custom job to modify properties using IExplorerUtil.
I noticed that after ~200 parts and assemblies updated, the RAM usage exceed 5GB. It seems that when executing many custom jobs in sequence, the InventorObecjt object of IJobProcessorServices is not released.
Is there an option to do this manually?
Vault API says that "This object should be initialized and released by framework. Extension developer doesn't need to take care of that." But apparently that seems not to be the case.
                ACET.IExplorerUtil explorerUtil = ACET.ExplorerLoader.LoadExplorerUtil(connection.Server, connection.Vault, connection.UserID, connection.Ticket);
                ACW.File vltFile = webServiceManager.DocumentService.GetLatestFileByMasterId(fileMasterId);
                explorerUtil.UpdateFileProperties(vltFile, properties);
I currently stop and restart the Jobprocessor.exe every five minutes to prevent it from crashing.
Many Thanks,
Jan
Replies (8)
Message 1 of 9
jan.wagnerRB67Z
Hi all,
Many Thanks,
Jan
Message 2 of 9
johannes.bauer
Autodesk Support
Autodesk Support
I suggest creating those posts in the Customization forum. Or create an ADN Case. Thanks
HTH
-Johannes
Customer Technical Success
Message 4 of 9
jan.wagnerRB67Z
Hey @johannes.bauer ,
i just did that. Feel free to delete this post.
Message 5 of 9
Markus.Koechl
Hi @jan.wagnerRB67Z, this is a known issue currently under investigation. However, the release of the InventorServerObject works in general. The issue relates to the use of IExplorerUtil, a wrapper that provides access to the Vault Client commands.
Markus Koechl
Solutions Engineer PDM, Autodesk Central Europe
Message 6 of 9
ihayesjr
You could try to changing the restart setting for the Job Processor.
Vault Help | Configure Job Processor Use Limits for CAD Services | Autodesk
Irvin Hayes Jr
Principal Product Manager
Autodesk, Inc.
Vault - Under the Hood Blog
Message 7 of 9
jan.wagnerRB67Z
@ihayesjr
We have them on 1/10 of the default value. Unfortunately they do not apply in this case.
Message 8 of 9
JelteDeJong
@Markus.Koechl
If the IExplorerUtil is a wrapper. Can i then conclude that if we would use the standard api (not the wrapper) that it would solve the issue?
Jelte de Jong
Blog: hjalte.nl - github.com
Message 9 of 9
Markus.Koechl
Hi @JelteDeJong. Yes, following the theory. At least, you get options to debug in depth. I am about to provide coding samples and kindly ask for patience while I finalize validation.
Markus Koechl
