03:43 PM
I use the attached code to change lifecycle states on files inside vault, based on the assembly bom open in inventor.
All works fine, but i manuel have to click the vault browser refresh button inside inventor to update the browser in inventor, is there anyway to do this via the API? Maybe this is a inventor customization question.
Please help!
Regards kent boettger
Private Sub CheckLifeCycleStateOnFiles(ByVal strVaultFilePath1WithoutFileName As String, ByVal mVaultfilename As String, ByVal strLocalFilePathWithoutFileName As String, ByVal strLocalFilePathWithFileName As String, ByVal DocSrv As DocumentService, ByVal DocSrvExt As DocumentServiceExtensions)
'Get hostname for FileCheckOut
Dim strHostName As String
strHostName = System.Net.Dns.GetHostName()
'Set the VaultFileName
Dim oVaultFileName As String = mVaultfilename
'Set the VaultFileFolder
Dim oVaultFileFolder As Folder = DocSrv.GetFolderByPath(strVaultFilePath1WithoutFileName)
'Loop because fileID changes when changing LifeCycleState
For i As Integer = 0 To 2
Dim oVaultFiles As Autodesk.Connectivity.WebServices.File() = DocSrv.GetLatestFilesByFolderId(oVaultFileFolder.Id, False)
For Each oVaultFile As Autodesk.Connectivity.WebServices.File In oVaultFiles
If oVaultFile.Name = oVaultFileName Then
Try
'Get FileID
Dim ThisFileID As Long = oVaultFile.Id
'Get FolderID
Dim ThisFileFolderID As Long = oVaultFileFolder.Id
'Get file master ID
Dim ThisFileMasterID() As Long = New Long() {DocSrv.GetFileById(oVaultFile.Id).MasterId}
'Create array of LyfecycleStates
Dim ThisFileLifeCycleState() As Long = New Long() {24, 25, 26, 27, 28}
'Lifecycle Definitions
'Name : Monsun Basic Release Process = 6
'Lifecycle States
'Work in Progress = LifecyclestateID 24
'For Review = LifecyclestateID 25
'Released = LifecyclestateID 26
'Obsolete = LifecyclestateID 27
'Ready for deletion = LifecyclestateID 28
Dim ThisFileLifecycleStateName As String = DocSrv.GetFileById(ThisFileID).FileLfCyc.LfCycStateName
Dim ThisFileLifeCyclestateID As Long = DocSrv.GetFileById(ThisFileID).FileLfCyc.LfCycStateId
Dim ThisFileLifeCycledefinitionID As Long = DocSrv.GetFileById(ThisFileID).FileLfCyc.LfCycDefId
'MsgBox("Filnavn : " & oVaultFile.Name & " FileID : " & ThisFileID & " FileMasterID : " & ThisFileMasterID(0) & " StatusNavn : " & ThisFileLifecycleStateName & " Status : " & ThisFileLifeCyclestateID)
' check if the file has status released
If ThisFileLifeCyclestateID = "26" Then
Try
'set the file to lifecycle state "for review" to prevent revision number change on checkout.
DocSrvExt.UpdateFileLifeCycleStates(New Long() {ThisFileMasterID(0)}, New Long() {ThisFileLifeCycleState(1)}, "Ax2009 Properties sync.")
Catch ex As Exception
MsgBox(ex.Message & " Error change from, Released to For review")
End Try
'check if the file has status "For Review"
If ThisFileLifeCyclestateID = "25" Then
Try
'set the file to lifecycle state "Work in Progress"
DocSrvExt.UpdateFileLifeCycleStates(New Long() {ThisFileMasterID(0)}, New Long() {ThisFileLifeCycleState(0)}, "Ax2009 Properties sync.")
MsgBox(ex.Message & " Error change from, For review to Work in progress")
End Try
'check if the file has status "Work in Progress"
If ThisFileLifeCyclestateID = "24" Then
Try
'check if the file is checked out if not check out the file
If oVaultFile.CheckedOut = False Then
Dim fileData As Byte() = Nothing
oVaultFile = DocSrv.CheckoutFile(ThisFileFolderID, ThisFileID, CheckoutFileOptions.Master, strHostName, strLocalFilePathWithFileName, "Ax2009 Properties sync.", False, False, fileData)
Dim mfilepath As String = (strLocalFilePathWithoutFileName & oVaultFileName)
SetFileReadAccess(oVaultFile, mfilepath)
MsgBox(ex.Message & "Error checking out file from Work i progress")
End Try
'check if the file has status "Obsolete"
If ThisFileLifeCyclestateID = "27" Then
MsgBox("The file " & strLocalFilePathWithFileName & " is set to, Obsolete - Replace the file with the new one")
'check if the file has status "Ready for Deletion"
If ThisFileLifeCyclestateID = "28" Then
MsgBox("The file " & strLocalFilePathWithFileName & " is set to, ready for deletion")
MsgBox(ex.Message & " Error in change lifecycle state")
End Try
Next
Next
End Sub
'Sets the read-only value of a file.
Sub SetFileReadAccess(ByVal LocalVaultfile As Autodesk.Connectivity.WebServices.File, ByVal LocalVaultFilePath As String) ', ByVal SetReadOnly As Boolean'ByVal LocalPath As String,
Try
Dim info As System.IO.FileInfo = New FileInfo(LocalVaultFilePath)
info.IsReadOnly = False
info.CreationTime = LocalVaultfile.CreateDate
MsgBox(ex.Message)
End Try
End Sub
