Images in Vault Data Standard
mtmarchant
mtmarchant
First off, I may be in the wrong section of the forums for this question. If that is the case, I do apologize.
I'm looking to add a screenshot image of our various numbering schemes - and what each designates - to our Vault Data Standard (VDS) pop-up that shows whenever you try and save an Inventor file for the first time. Is this possible to do? I made a back-up of my original VDS Powershell code to do some playing around, but I am a complete novice with programming and am not having any luck.
Here's the original code:
function InitializeWindow
	#begin rules applying commonly
    $dsWindow.Title = SetWindowTitle
    InitializeCategory
    InitializeNumSchm
    InitializeBreadCrumb
    InitializeFileNameValidation
	#end rules applying commonly
	$mWindowName = $dsWindow.Name
	switch($mWindowName)
		"InventorWindow"
			#rules applying for Inventor
		"AutoCADWindow"
			#rules applying for AutoCAD
	$global:expandBreadCrumb = $true
function AddinLoaded
	#Executed when DataStandard is loaded in Inventor/AutoCAD
function AddinUnloaded
	#Executed when DataStandard is unloaded in Inventor/AutoCAD
function InitializeCategory()
    if ($Prop["_CreateMode"].Value)
		if (-not $Prop["_SaveCopyAsMode"].Value)
            $Prop["_Category"].Value = $UIString["CAT1"]
function InitializeNumSchm()
	#Adopted from a DocumentService call, which always pulls FILE class numbering schemes
	$global:numSchems = @($vault.NumberingService.GetNumberingSchemes('FILE', 'Activated'))
			$Prop["_Category"].add_PropertyChanged({
				if ($_.PropertyName -eq "Value")
					$numSchm = $numSchems | where {$_.Name -eq $Prop["_Category"].Value}
                    if($numSchm)
                        $Prop["_NumSchm"].Value = $numSchm.Name
		else
            $Prop["_NumSchm"].Value = "None"
function GetVaultRootFolder()
    $mappedRootPath = $Prop["_VaultVirtualPath"].Value + $Prop["_WorkspacePath"].Value
    $mappedRootPath = $mappedRootPath -replace "\\", "/" -replace "//", "/"
    if ($mappedRootPath -eq '')
        $mappedRootPath = '$'
    return $vault.DocumentService.GetFolderByPath($mappedRootPath)
function SetWindowTitle
  		"InventorFrameWindow"
   			$windowTitle = $UIString["LBL54"]
  		"InventorDesignAcceleratorWindow"
   			$windowTitle = $UIString["LBL50"]
  		"InventorPipingWindow"
   			$windowTitle = $UIString["LBL39"]
  		"InventorHarnessWindow"
   			$windowTitle = $UIString["LBL44"]
  		default #applies to InventorWindow and AutoCADWindow
    			if ($Prop["_CopyMode"].Value)
     				$windowTitle = "$($UIString["LBL60"]) - $($Prop["_OriginalFileName"].Value)"
    			elseif ($Prop["_SaveCopyAsMode"].Value)
     				$windowTitle = "$($UIString["LBL72"]) - $($Prop["_OriginalFileName"].Value)"
    			}else
     				$windowTitle = "$($UIString["LBL24"]) - $($Prop["_OriginalFileName"].Value)"
   			else
    			$windowTitle = "$($UIString["LBL25"]) - $($Prop["_FileName"].Value)"
  	return $windowTitle
function GetNumSchms
	$specialFiles = @(".DWG",".IDW",".IPN")
    if ($specialFiles -contains $Prop["_FileExt"].Value -and !$Prop["_GenerateFileNumber4SpecialFiles"].Value)
        return $null
	if (-Not $Prop["_EditMode"].Value)
		if ($numSchems.Count -gt 1)
			$numSchems = $numSchems | Sort-Object -Property IsDflt -Descending
            $noneNumSchm = New-Object 'Autodesk.Connectivity.WebServices.NumSchm'
            $noneNumSchm.Name = $UIString["LBL77"]
            return $numSchems += $noneNumSchm
        return $numSchems
function GetCategories
	return $Prop["_Category"].ListValues
function OnPostCloseDialog
		"InventorWindow"
		"AutoCADWindow"
		default
			#rules applying commonly
And here's my modified code:
    InitializeCategory
    InitializeNumSchm
		"InventorWindow"
			LoadBreadCrumpPreselection "Inventor"
		"AutoCADWindow"
			LoadBreadCrumpPreselection "AutoCAD"
                    if($numSchm)
		else
    			}else
   			else
  	return $windowTitle
        return $null
        return $numSchems
	#return $Prop["_Category"].ListValues
    $mAllCats = $vault.CategoryService.GetCategoriesByEntityClassId("FILE", $true)
    $mCADCats = @("Projects", "Standard Parts") #list all category names to be available
    $mFilteredCats =  $mAllCats | Where { $mCADCats.Contains($_.Name) }
    return $mFilteredCats
		"InventorWindow"
			SaveBreadCrumpPreselection "Inventor"
		"AutoCADWindow"
			SaveBreadCrumpPreselection "AutoCAD"
		default
function SaveBreadCrumpPreselection($appName)
 $path = "C:\temp\$($vaultConnection.Vault)_$($appName)_BreadCrump.txt"
 $breadCrumb = $dsWindow.FindName("BreadCrumb")
 $selection = @()
 foreach ($cmb in $breadCrumb.Children)
 $selection += $cmb.SelectedIndex
 $selection | Out-File $path
function LoadBreadCrumpPreselection($appName)
 if (Test-Path -Path $path)
 $selection = Get-Content $path
 for ($index = 0; $index -lt $selection.Count; $index++)
 try
 $dsWindow.FindName("cmbBreadCrumb_"+$index).SelectedIndex=$selection[$index]
 catch
#set icon for form using Base64
$base64IconString = "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"
$iconimageBytes = [Convert]::FromBase64String($base64IconString)
$ims = New-Object IO.MemoryStream($iconimageBytes, 0, $iconimageBytes.Length)
$ims.Write($iconimageBytes, 0, $iconimageBytes.Length);
$alkIcon = [System.Drawing.Image]::FromStream($ims, $true)
$Form.Icon = [System.Drawing.Icon]::FromHandle((new-object System.Drawing.Bitmap -argument $ims).GetHIcon())
#add an image to the form using Base64
$base64ImageString = "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"
$imageBytes = [Convert]::FromBase64String($base64ImageString)
$ms = New-Object IO.MemoryStream($imageBytes, 0, $imageBytes.Length)
$ms.Write($imageBytes, 0, $imageBytes.Length);
$alkanelogo = [System.Drawing.Image]::FromStream($ms, $true)
$pictureBox = new-object Windows.Forms.PictureBox
$pictureBox.Width =  $alkanelogo.Size.Width;
$pictureBox.Height =  $alkanelogo.Size.Height;
$pictureBox.Location = New-Object System.Drawing.Size(85,20)
$pictureBox.Image = $alkanelogo;
$form.Controls.Add($pictureBox)
Mack Marchant - Project Engineer
Majjek
I'm also very interested in how to modify the generate file numbers screen.
For example with adding a button or an image or something.
I'll follow this thread.
