how to read/write comment for Change Order
wesbird
wesbird
  I have to problem to read/write command for change order.
  for read, I cannot find the funciton
  for write, there are a lot of function: AddComment, UpdateChangeOrder all should works, which one should I use
  when I play with UpdateChangeOrder, I have problem to construct Msg and MsgGroup. Here is my code:
            Msg msg = new Msg();
            msg.MsgTxt = "MsgTxt test";
            msg.Subject = "Subject abc";
            MsgGroup mg = new MsgGroup();
            mg.Msg = msg;
            MsgGroup[] msgs = new MsgGroup[] { mg };
            m_cache.Conn.WebServiceManager.ChangeOrderService.AddComment(co.Id, msgs, null);
  How I can make it works?
Wes
Windows 10 64 bit, AutoCAD (ACA, Map) 2023
minkd
What version of Vault Pro are you using?
What error do you get?    The full exception from the vlog would be helpful.
What state is the change order in?    Only users with certain routing-roles can add comments in certain change order states See this for details.
-Dave
Dave Mink
Fusion Lifecycle
Autodesk, Inc.
wesbird
Hi Dave:
  It works now. I did not remember I change anything.
  It's Vault Pro 2014.
  I did not check vlog yesterday, here it is:
2014-07-10 1:42:04 PM *******************************************************************
Error: Soap Exception ( mesg-id = 635405965241209577 )
Exception: NullMsgComponents [1686]
Stacktrace:
Server stack trace:
at Connectivity.Process.Services.ChangeOrderService.UpdateChangeOrder(Int64 coId, String changeOrderNumber, String title, String description, DateTime approveDeadline, Int64[] addItemMasterIds, Int64[] delItemMasterIds, Int64[] addAttmtMasterIds, Int64[] delAttmtMasterIds, Int64[] addFileMasterIds, Int64[] delFileMasterIds, PropertyInstance[] addProperties, Int64[] delPropDefIds, ForumMessage[] comments, ArrayList[] commentFileAttachs, ForumMessageEmail[] notifyEmails, AssociationPropertyItem[] addAssocProperties, Int64[] delAssocPropIds, Int64 routingId, ArrayList addUserIds, ArrayList addRoleIds, ArrayList delUserIds, ArrayList delRoleIds)
at System.Runtime.Remoting.Messaging.Message.Dispatch(Object target)
at System.Runtime.Remoting.Messaging.StackBuilderSink.SyncProcessMessage(IMessage msg)
Exception rethrown at [0]:
at System.Runtime.Remoting.Proxies.RealProxy.HandleReturnMessage(IMessage reqMsg, IMessage retMsg)
at System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke(MessageData& msgData, Int32 type)
at Connectivity.Web.Services.v18.ChangeOrderService.UpdateChangeOrder(Int64 changeOrderId, String changeOrderNumber, String title, String description, DateTime approveDeadline, Int64[] addItemMasterIds, Int64[] delItemMasterIds, Int64[] addAttmtMasterIds, Int64[] delAttmtMasterIds, Int64[] addFileMasterIds, Int64[] delFileMasterIds, PropertyInstance[] addProperties, Int64[] delPropDefIds, ForumMessageGroup[] addComments, ForumMessageEmail[] notifyEmails, AssociationPropertyItem[] addAssocProperties, Int64[] delAssocPropIds, Int64 routingId, RoutingRoleMap[] addMembers, RoutingRoleMap[] delMembers)
at SyncInvokeUpdateChangeOrder(Object , Object[] , Object[] )
at System.ServiceModel.Dispatcher.SyncMethodInvoker.Invoke(Object instance, Object[] inputs, Object[]& outputs)
at System.ServiceModel.Dispatcher.DispatchOperationRuntime.InvokeBegin(MessageRpc& rpc)
at System.ServiceModel.Dispatcher.ImmutableDispatchRuntime.ProcessMessage5(MessageRpc& rpc)
at System.ServiceModel.Dispatcher.ImmutableDispatchRuntime.ProcessMessage31(MessageRpc& rpc)
at System.ServiceModel.Dispatcher.MessageRpc.Process(Boolean isOperationContextSet)
  I will remember check vlog more later.
Thank you for your time
Wes
minkd
FYI: That particular error is only thrown when a MsgGroup with a Msg is provided, but the Msg has either a null Subject or null MsgTxt.
-Dave
Dave Mink
Fusion Lifecycle
Autodesk, Inc.
