How to change the Priority settings in job processor
robincharly
robincharly
Hai Team,
I implemented the vault professional in my customer end, Now they want to use the vault job processor & also want to change the job processor priority settings for the files they need to set priority, by using vault API.
Kindly guide me on this asap.
Thanks in advance.
Nick_Hall
Hi
If the job is already in the queue, the only way to change the priority is to "get" the job, delete it, and re-add it with a different priority
You will need the JobService API Calls GetJobsByDate, DeleteJobById, and AddJob
Hope that helps
Nick
jaco011
Hi, Do you know how to change the priority before it is in the queue?
mateusz_baczewski
As far as I remember, there's no such possibility. Unless you're adding a task to the queue using your own application/PowerShell, then you can modify it during the addition.
_vaultConn.WebServiceManager.JobService.AddJob("xxx.UpdateProperties", $"xxxx.UpdateProperties: {assemblyFile.File.Name}", jobParams, 1(priority));
Read:
Increase/decrease the priority of jobs of Vault job processor
If you found it helpful, a "Like" would be much appreciated!
If this post solved your problem, please mark it as "Solution.".
Nick_Hall
Hi
@mateusz_baczewski is correct.
But, according to the recent comments on this Idea from 2012 - https://forums.autodesk.com/t5/vault-ideas/job-queue-priority-settings/idi-p/3543728 - it looks like Autodesk has started looking into Job Queue management
You can contribute to the discussion if you join the Vault Beta program - there is a link in the discussion
Nick
