GetLatest on a folder
rikard.nilsson
rikard.nilsson
I'm trying to do my first Vault program in a long time.
What I'm trying to do is to preform a GetLastest on a folder.
I have added a VaultBrowserControl and there picked a folder.
I then thought that I caould use "AddEntityToAcquire".
You can see my test below that I can't get to work.
Can anyone lead me in the right direction to solve my GetLastest on a folder?
And it would be perfect if I then could get the local path that was created with GetLatest to use later in my program to save my files to..
Regards
Rikard
Vault.Currency.Entities.Folder foundFolder { get; set; }
Vault.Settings.AcquireFilesSettings settings = new Vault.Settings.AcquireFilesSettings(m_conn);
settings.AddEntityToAcquire(foundFolder);
Vault.Results.AcquireFilesResults results = m_conn.FileManager.AcquireFiles(settings);
wayne.brill
Hi Rikard,
I did a quick test with this SDK sample:
C:\Program Files (x86)\Autodesk\Autodesk Vault 2016 SDK\vs12\CSharp\VaultBrowserSample
With  a few edits it was able to download all the files from a folder. (they were the latest versions). Below are the changes I made. Maybe you could update that sample to show what the problem is you are getting. Also explain where the error occurs and what it is.
public partial class Form1 : Form
        #region Member Variables
        //WB made public and static
        //private Vault.Currency.Connections.Connection m_conn = null;
        public static Vault.Currency.Connections.Connection m_conn = null;
void m_model_SelectedContentChanged(object sender, Forms.Currency.SelectionChangedEventArgs e)
            //when the selected content changes, we need to update the filename field to reflect the selected entities
            List<Vault.Currency.Entities.IEntity> selectedEntities = new List<Vault.Currency.Entities.IEntity>(e.SelectedEntities);
           // bool fileSelected = false;
            //WB testing - so I can run the Open command with a folder selected
            bool fileSelected = true;
 private void OpenFile()
           //WB testing - running a new function that downloads a folder
            Vault.Currency.Entities.Folder fldr = m_model.SelectedContent.FirstOrDefault() as Vault.Currency.Entities.Folder;
            string folderPath = System.IO.Path.Combine(Application.LocalUserAppDataPath, "WB_Test");
            OpenFileCommand.downloadFile_WB(m_conn, fldr, folderPath);
            return;
            //WB end
  //WB added
  //     private static void downloadFile_WB(VDF.Vault.Currency.Connections.Connection connection, VDF.Vault.Currency.Entities.Folder fldr) //, string folderPath)
       public static void downloadFile_WB(VDF.Vault.Currency.Connections.Connection connection, VDF.Vault.Currency.Entities.Folder fldr, string folderPath)
           VDF.Vault.Settings.AcquireFilesSettings settings = new VDF.Vault.Settings.AcquireFilesSettings(connection);
           settings.AddEntityToAcquire(fldr);
           settings.LocalPath = new VDF.Currency.FolderPathAbsolute(folderPath);
           connection.FileManager.AcquireFiles(settings);
       //WB end added
Wayne
Wayne Brill
Developer Technical Services
Autodesk Developer Network
rikard.nilsson
Thanks Wayne!
I did not have settings.localPath.. That did the trick..
/Rikard
