Get change order user defined property by Vault Api problem
Chiften
Chiften
hi.
i want to get a user defined properties value of my change orders by vault api using c#.
how can i get value of a user defined properties named : Responsible discipline
i write this code but it doesn't work.
            foreach (var changeOrder in AllChangeOrders)
                MessageBox.Show(changeOrder.Num);
                // Get the user-defined property definition for "Responsible Discipline"
                PropDef responsibleDisciplinePropDef = VaultConnection.WebServiceManager.PropertyService.GetPropertyDefinitionsByEntityClassId("CUSTENT_CHANGEORDER")
                        .FirstOrDefault(pd => pd.DispName == "Responsible Discipline");
                if (responsibleDisciplinePropDef != null)
                    // Get the value of the "Responsible Discipline" property for the change order
                    PropInst responsibleDisciplinePropInst = VaultConnection.WebServiceManager.PropertyService.GetProperties("CUSTENT_CHANGEORDER", new long[] { changeOrder.Id }, new long[] { responsibleDisciplinePropDef.Id })
                        .FirstOrDefault();
                    string responsibleDisciplineValue = (string)responsibleDisciplinePropInst.Val;
please help me .
thank you
Markus.Koechl
The entity class id for Change Order is "CO"; you need to change "CUSTENT_CHANGEORDER" to "CO".
Markus Koechl
Solutions Engineer PDM, Autodesk Central Europe
