General error 0 description 109 when checking in a file
I have written code to rename files to match on of its Iproperties. This all works fine, most of the time. Since we have switched to Vault 2023 from 2020 I am getting some complaints from the users. The need to run the code a few times for it to work. The error is 0 with a description of 109.
Looking in the vlogs it seems to say this: Conversion failed when converting the nvarchar value 'User Name' to data type int. I substituted User Name for the actual name of the user.
3 questions,
1. Why does it work sometimes?
2. Why is it trying to convert the user name to an int (I assume this is integer)?
3. How do I make the error stop?
I include the entire error below.
8/29/2022 5:14:29 PM *******************************************************************
Error: Soap Exception ( mesg-id = 637973900697596154 )
Exception: DatabaseError [109]
Stacktrace:
Server stack trace:
Exception rethrown at [0]:
at System.Runtime.Remoting.Proxies.RealProxy.HandleReturnMessage(IMessage reqMsg, IMessage retMsg)
at System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke(MessageData& msgData, Int32 type)
at Connectivity.Document.Services.FileService.CheckinUploadedFile(Int64 fileMasterId, String comment, Boolean keepCheckedOut, DateTime lastWrite, FileAssociationParam[] associations, BOM bom, Boolean copyBom, String newFilename, FileClassification fileClassification, Boolean hidden, UploadTicket uploadTicket)
at Connectivity.Web.Services.v28.DocumentService.CheckinUploadedFile(Int64 fileMasterId, String comment, Boolean keepCheckedOut, DateTime lastWrite, FileAssociationParam[] associations, BOM bom, Boolean copyBom, String newFileName, FileClassification fileClassification, Boolean hidden, ByteArray uploadTicket)
at SyncInvokeCheckinUploadedFile(Object , Object[] , Object[] )
at System.ServiceModel.Dispatcher.SyncMethodInvoker.Invoke(Object instance, Object[] inputs, Object[]& outputs)
at System.ServiceModel.Dispatcher.DispatchOperationRuntime.InvokeBegin(MessageRpc& rpc)
at System.ServiceModel.Dispatcher.ImmutableDispatchRuntime.ProcessMessage5(MessageRpc& rpc)
at System.ServiceModel.Dispatcher.ImmutableDispatchRuntime.ProcessMessage11(MessageRpc& rpc)
at System.ServiceModel.Dispatcher.MessageRpc.Process(Boolean isOperationContextSet)
Exception(Inner): Conversion failed when converting the nvarchar value 'User Name' to data type int.
Stacktrace(Inner): at Connectivity.Core.Database.TransactionContext.OnSqlException(SqlException e)
at Connectivity.Core.Database.SqlAccess.ExecuteReaderInternal(SqlCommand cmd)
at Connectivity.Core.Database.SqlAccess.ExecuteReader(CommandType commandType, String commandText, SqlParameter[] commandParameters, Int32 commandTimeout)
at Connectivity.Core.DataAccess.Director.InvokeCommand()
at Connectivity.Document.DataAccess.Files.CheckinFile(Int64 fileMasterId, Nullable`1 checkinDate, DateTime modDate, String comment, Int32 checksum, Int64 fileSize, Boolean dependenciesChanged, FileAssociationParam[] associations, Boolean allowUncommittedDependencies, BOM bom, String fileName, FileClassification fileClassification, Boolean hidden, Boolean performSecurityCheck, Int64 contentSourceId, Nullable`1 resourceGuid, String& generartedBomData)
at Connectivity.Document.BusinessLogic.FileBL._CheckinFile(Int64 fileMasterId, String comment, Nullable`1 checkinDate, DateTime lastWrite, Int32 checksum, Int64 fileSize, Boolean dependenciesChanged, FileAssociationParam[] associations, Boolean allowUncommittedDependencies, BOM bom, String fileName, FileClassification fileClassification, Boolean hidden, File fileToCopyResourceFrom, Boolean skipIndexing, Boolean performSecurityCheck, Int64 contentSourceId, UploadTicket uploadTicket)
at Connectivity.Document.BusinessLogic.FileBL.CheckinUploadedFile(Int64 fileMasterId, String comment, Boolean keepCheckedOut, Int64 checkinUser, Nullable`1 checkinDate, Nullable`1 lastWrite, FileAssociationParam[] associations, Boolean allowUncommittedDependencies, BOM bom, Boolean copyBom, String newFilename, FileClassification fileClassification, Boolean hidden, CheckinOptions options, UploadTicket uploadTicket)
at System.Runtime.Remoting.Messaging.StackBuilderSink._PrivateProcessMessage(IntPtr md, Object[] args, Object server, Object[]& outArgs)
at System.Runtime.Remoting.Messaging.StackBuilderSink.SyncProcessMessage(IMessage msg)
