Filter out unnecessary categories in VDS dialog box
alex_hiis6PJP6
alex_hiis6PJP6
Hey
I there a way to make changes to the Default.ps1 file to remove unnecessary Categories when VDS dialog box is triggered during an inital save in Inventor?
Nick_Hall
Hi
The function you need to change is GetCategories
function GetCategories
  if ($dsWindow.Name -eq "FileWindow")
    return $vault.CategoryService.GetCategoriesByEntityClassId("FILE", $true)
  elseif ($dsWindow.Name -eq "FolderWindow")
    return $vault.CategoryService.GetCategoriesByEntityClassId("FLDR", $true)
  elseif ($dsWindow.Name -eq "CustomObjectWindow")
    return $vault.CategoryService.GetCategoriesByEntityClassId("CUSTENT", $true)
You need to change this part so that only the values you want are returned
If you want a hand with the actual filtering code, let me know if
  • You want to exclude the marked categories by name, and return everything else
    Or
  • You want to include specific categories and return only those
Hope that helps
Nick
alex_hiis6PJP6
Yes, I would appreciate the help. I would like to return values "Engineering" "Purchased" "Reference".
alex_hiis6PJP6
I think I got it.
I replaced your mentioned line with:
    $allCategories = $vault.CategoryService.GetCategoriesByEntityClassId("FILE", $true)
    $allowedCategoryNames = @("Engineering", "Purchased", "Reference")
    $filteredCategories = $allCategories | Where-Object { $allowedCategoryNames -contains $_.Name }
    return $filteredCategories
Can't seemed to get a similar solution to work in Inventor tho.
