file path of vault file
I'm programming in C# in vault 2018. What I need is the path of a file in Vault. I searched the net but can't find a code snippet of it.
I vault I can see Path = $/Myworkfolder/InventorTestProject  , but how can I find this path in code ? I don't want to download the file, just open it.
Can anyone help ?
never mind, found it 🙂
danijel.radenkovic
Hello @Anonymous,
I have the same problem, finding a Vault path of the specific file in Vault. Would you like to provide a way how you did it?
Best,
Danijel
Inventor 2018/Windows 10 x64
If this information was helpful, please consider marking it as an Accepted Solution by using the Accept as Solution. Kudos are also gladly accepted.
I am sorry, but it can't remember for what project I needed this, it has been too long ago.
But I am sure I found it on google somewhere.
Tim_Kreutzer
What information do you have to identify the file? Its name? The DocumentService class has a GetLatestFilePathsByNames method.
FilePathArray filePathArray = WebServiceManagerObject.DocumentService.GetLatestFilePathsByNames(new string[] { "MyFileName.ext" });
string MyVaultPath = filePathArray.FilePaths[0].Path;
(written off the top of my head, may not be accurate)
Beside that, there is FindFilesBySearchConditions()
