Error in Connecting to Vault 2020 using ASP.NET Web API Application
I have created ASP.NET web API application with .NET Framework 4.7
I am using Vault 2020 Professional version.
I have added following DLLs in references in my application.
  1. Autodesk.Connectivity.WebServices
  2. Autodesk.Connectivity.WebServices.WCF
However when I run the application I am getting the following error.
Could not load file or assembly "Autodesk.Connectivity.LicenseWrapper" or one of its dependencies. An attempt was made to load a program with an incorrect format.
@psaarloos
@ivan_gani
Any help on this will be really appreciated.
ivan_gani
Did you copy even the AdskLicensingSDK_2.dll file?
Hi Ivan,
Yes, I have copied AdskLicensingSDK_2.dll inside bin folder.
Still getting the same error.
ivan_gani
you should copy the AdskLicensingSDK_2.dll not on bin folder, but on the windows system32 folder (where the iis exe is located)
Please see my older post:
https://forums.autodesk.com/t5/vault-customization/64-bit-standalone-vault-2020-client-login-fails-i...
