Custom Entity - HideDefaultTabViews
Nick_Hall
Nick_Hall
I'm trying to turn off the Default Tabs for my custom entity, and it doesn't appear to work
I have a custom tab that is working as I want, but it would look better if the default tabs were not there
The code I have is below, but it can't be that simple (because otherwise it would work)
Can someone tell me where I'm going wrong
Nick
public IEnumerable<CustomEntityHandler> CustomEntityHandlers()
  CustomEntityHandler handler = new CustomEntityHandler("b1f67d6a-0666-4e94-ab23-0b06fed712e1")
    HideDefaultTabViews = true
  return new CustomEntityHandler[] { handler };
Markus.Koechl
You need to collect all existing tabs, add your custom one and use as a replacement. Find uploaded an extended SDK sample "Hello World" that implements this approach. A preview of the code:
DetailPaneTab mExisting = new DetailPaneTab("File.Tab.MyGrid", "OverrideTab", SelectionTypeId.File,
                typeof(DetailPaneTab));
            fileTabs.Add(mExisting);
            mExisting.Replaces = "File.Versions"; // .Uses, .WhereUsed, .View ;see application.TabPageIds for valid values (break log on to review)
Note - the sample is Vault API 2018.
Markus Koechl
Solutions Engineer PDM, Autodesk Central Europe
Nick_Hall
Hi Markus
That works well & I have my tab replacing one of the Custom Object tabs
There are two standard Custom Object tabs, and I don't really want either to be visible
I've "fixed" it for now by adding an "About" tab and using this as a replacement for the second (which isn't too bad), but is it possible to hide the tab completely?
Thanks for your help so far
Nick
Markus.Koechl
Hi Nick,
As far as I oversee the principle we need to have a 1:1 ratio of default tabs being replaced and custom tabs working as a replacement.
Markus Koechl
Nick_Hall
Hi Markus
That's fine. I can work around that
Nick
