Cursor memory
Cursor memory
Raymond_Leedom
Observer Observer
Cursor memory
Raymond_Leedom
Observer
Observer
First, I am not sure Cursor Memory is the right term. When I am copying a design from vault, and I select add files, I have to start at the top level every time. My question is, is there a way for the program to remember the last place, or level, I selected from when adding files?
Markus.Koechl
You mean that the Select from Vault Tree does not expand to the last used folder if you repeatedly Add Files... in Copy Design?
Programmatically, there is an option to save this into the user's ApplicationPreferences.xml. We probably missed leveraging it for the Add Files... of Copy Design. I will check.
Markus Koechl
Solutions Engineer PDM, Autodesk Central Europe
Raymond_Leedom
Observer
Observer
Yes, that is what I mean. Thanks
Markus.Koechl
Thank you for the heads-up. We checked and validated that Copy Design misses the automatic save of the last used folder. Future updates will target resolving this. Thanks again.
Markus Koechl
